What size rear swaybar end links?
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
I need to buy rear sway bar end link bushings and I am not sure what size I need. Can someone please tell me what part number to order from jegs or summit. Thanks.
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: What size rear swaybar end links?
Along these same lines, I am switching to polyurethane all around. I looked on summit for sway bar bushing kits for our cars and came up with 3 options. The bushing sizes, for the center support bushings, range from 30-34mm in size for the front, and 19-24mm in the rear. Is there any way to distiguish between these sizes without buying a pair of calipers and measuring them both for myself?
I attached a picture of the piece in question.
JamesC
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Harbor Freight sells a really nice digital caliper for $35. It measures in inches as both a decimal and a fraction, and also in millimeters, just press a button to change units. You can also zero it out and all that fancy stuff and it is accurate to .001 inches. It also comes with an extra battery (I have been using mine a lot over the past year and still haven't needed the spare).
Perfect, I'll check Harbor Freight for those calipers and order one up.
Thanks for the information,
Josh
Josh
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
NAPA has a nice little set of end links for the sway bars... $24
I really like the center piece in the kit.
http://www.napaonline.com/masterpage...ear+Suspension
Much appreciated.
Engine: LB9 & L98
no prob... They are actually a little beefier than all the others too...
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
