295/50-16 et streets
Car: 1986 berlinetta
Axle/Gears: 10 bolt with 3.73s
Will they fit the same as BF Goodrich's 295/50-16s. Ive done a bit of research and i know that the BFGs will fit on the stock 16x8 rims and will have no clearance problems with some hammering and such. I just need to know if the ET street radials of the same size will fit the same. Any responses are appreciated, thanks.
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: 295/50-16 et streets
They should fit specially if the bfgs are known to fit. I've run a 275/50/15, which is similar height, but shy about .9" of width from the ones you're looking at. My guess is that it'll take some mild hammering/clearancing on the front of the inner fender. I'm about to make some 325/50/15's fit next week, and that may be a chore.
Doobie52
09-11-2015 06:19 PM
