Front End Noise
Car: 92 Camaro RS
Engine: 3.1
Front End Noise
Don't know if this is the right place for this or not but here it goes anyway. I have a 92 camaro and whenever I turn left or right I heard a thump sound in the front end. You only hear it when you turn. Is this possibly the barrings bad? Any help would greatly be appreciate.
Thanks Dsull
Thanks Dsull
Car: 1991 Firebird T-Top
Engine: 305 tbi
Transmission: t-5 manual
Axle/Gears: 3.08 Open
Re: Front End Noise
Its tough to say for sure, but it could be as simple as the wheels catching on loose plastic in the fender well. If your driving and you rock the steering wheel back and forth does it clunk? If so it's more than likely a steering box which will run about $50 from a wrecker. But for $30 and 20min of your time a shop will jack up the front end and check all your parts after a road test
Terrell351
06-13-2021 01:13 PM
