Is it bad to grease the endlinks on out cars?
Im getting squeaks from my rear left and I want it to go away. I do remember hearing somewhere that your not supposed to. Just want to make sure.
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Is it bad to grease the endlinks on out cars?
There are no endlinks in the rear of thirdgens. Are you talking about the control arms?
Hmm sorry if I dont know any better but the bushings that go on the end of the sway bars. I thought they were called endlinks. I do have a rear sway bar.
1 Post
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
well got down and couldn't get up, should he grease them or not, could be from the pan hard also........
1 Post
you know personaly i see no problem with it, but if i was going to take it off to grease it would go get some poly bushing to replace the rubber ones
Ohh forgot to mention they are poly bushings.
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
poly bushings always love grease as long as its synthetic and not petroleum based(will eat the bushings)
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
silicone grease or moli grease will work, anything made from petroleum will melt it
Definately grease the swaybar bushings, they even come with a little packet of the stickiest grease I've ever seen...
Endlinks, well greasing really won't do much there; unless you foresee r&r'ing them more than once in their life cycle (ei. 4x4 offroading) in which case some antiseize on the shaft and threads may be a nice thing...
1 Post
Car: 1987 IROC-Z
Transmission: TH350
Oops. I clicked the wrong thread.
1992 Trans Am
08-08-2015 08:16 PM
