Does anyone know the swaybar wall thickness'?
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Like the title says, does anyone know the different thickness' of the swaybars for our vehicles? Is the thickness the same no matter the diameter of the bar?
Thanks,
Mike
Thanks,
Mike
1 Post
Car: 1987 IROC-Z
Transmission: TH350
Re: Does anyone know the swaybar wall thickness'?
Does anyone have any idea how I could measure this?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Why would you need to measure it?
1 Post
Car: 1987 IROC-Z
Transmission: TH350
I'm trying to make a program to compare the stiffness of the different sized sway bars. This way, when someone says "yeah, swapping from a 23 solid to a 24 solid made a huge difference," I actually have proof that it does (it is roughly 18.56% stiffer). Anything below 10% cannot be felt by the average driver.
I only have a 34 hollow and a couple 36 hollows to get the measurement from. I guess I'll just try and use a piece of wire to figure out the thickness of each bar.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Measure the length of a drill bit, then zero your calipers on that. Then stick the drill bit in, and measure length of drill bit + wall thickness. That'll be your wall thickness.
Maybe a few other members will be willing to measure theirs as well for ya.
1 Post
Car: 1987 IROC-Z
Transmission: TH350
1 Post
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
so a used 1" is the same as a new one? Or am i reading it wrong?
would be very interested in the data from the front sway bars
1 Post
Transmission: 4L60
ah i see
RedLeader289
05-28-2019 01:47 PM
roysatikas
09-22-2015 08:15 PM
