cracked lugnuts
cracked lugnuts
Hey guys. I just bought a camaro and i am about to put some cragars on it. Well a few of the lugnuts that are currently on the truck are either cracked, swollen, or both. I am not sure how to get the lugnuts of. My socket is either to big or to small b/c of these issue.
Does anyone have a little trick to get them off so i can put my new wheels on?
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: cracked lugnuts
Swollen lug nuts huh? Better watch where you're sticking your tire iron... ![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
Seriously though, I don't think they can "swell" unless it's just rust on them, in which case I would try to knock off as much as possible, and drive the lug wrench on with a hammer.
Some lugs are actually just a nut, with a chrome cap on it. You could try driving a screw driver into the cap, and see if it punches through. If it does, find a way to get that chrome cap off, and then use your wrench on the nut.
Re: cracked lugnuts
well i know its not a cap covering the lug nut. its just a lugnut on there. And maybe its not swollen, but the way it is cracked made the lugnut bigger on the sides than it normaly is. i dunno if i can explain it lol
anyways maybe ill just try and pound an old socket on and wrech it off that way
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Re: cracked lugnuts
cheap chrome lugnuts get rust under the cover/coating and flare out
Just hammer the socket over them
TheCardinal
Interior Parts Wanted
10-09-2015 09:43 PM
