Koni VS Lakewood
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Koni VS Lakewood
I just wanted to know are the koni yellows alot better than these or are these comparable?
thanks
kevin
Lakewood Shock/Strut - Front - Performance
Street/Strip Drag 70/30 series 159.99 bucks
thanks
kevin
Guest
Posts: n/a
Re: Koni VS Lakewood
Lakewoods are for street strip (ie drag race) and are valved to help lift the nose and provide motion transfer to load the rears. in other words, they are a "mid compression valve/low rebound valved strut". Konis are more for street /light road track use. They are mid compression and high rebound and are better suited to control body roll rates into cornering.
I really dont know what to buy but what i want is to beable to corver very well with not a hole lot a body roll. So what will help my car road race during rallies around me?
thanks
kevin
thanks
kevin
OK man sounds good is their any other big thing i can do?
kevin
kevin
Car: 87 formula
Engine: 5.0 TPI
There's a lot you can do. Subframe connectors make a big difference if you haven't done those yet. Most people recommend doing those first. I've seen Vetruck say the raised strut mounts with spherical bushings make a big difference, I'd take his word on that. You can get a set of sway bars (36/24 mm) out of a WS6 car. There's a whole long list of things you can do that will make a nice difference. Depends on how much you want to spend on it.
Hotrodboba400
12-10-2019 07:07 PM
LT1Formula
10-08-2015 08:34 PM
