Back halfing my 86 IROC
#51
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
Re: Back halfing my 86 IROC
lookin real sharp, nothings nicer than a back-hlaf car actually sits the way its supposed to
#52
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Here is the last, carpet has been put in
#55
Car: 92 Rs
very clean job, i really appriciate nice fab work when you find it. carpet job looks real clean. car sits correct as well!
Awesome
Luke
Awesome
Luke
#56
Some people have been PMing me about pictures of the drop spindles and rack and pinion
#57
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
damn it man your making me want to sell my spohn tq arm and tranny mount combo and go ahead and tubb another vehicle. id have a tubbed s10 and tubbed camaro. stop posting pics so i dont have to do this
the sad part is i already have a set of 15x14 wheels. and a set of brand new mt sportsman 31x18.5 tires and a set of sportsman pro 29x18.5. all thats missing is a ed quay back half kit and a rearend from him setup for his four link
#58
Car: 89 Iroc Z
Engine: Carburated 427 Smallblock
Transmission: 400 Turbo
Nice looking outfit you have there......... "to say the least" !!!
I have a couple of questions for you if you dont mind? I understand why you went with the aftermarket spindle assembly, "turning radius issues with a manual rack conversion", but what is the reason for the 2" lowering portion of the aftermarket spindle assemblys? Did you really want or need to lower the cars ride height or did you just have to accept it since that's the way the aftermarket spindle assemblys come while dealing with the turning radius issues? Secondly, did you go with a coilover set-up in the front? If so what brand of components did you select. Sorry for all of the questions, but I'm involved in a similar process with my 89 and I'm kinda stumped on what really is the best way for me to proceed.
Thanks a million, Bruce
#59
I decided not to go with coil overs, I orginally wanted to, but the more I read I changed my mind, I just did not trust all that weight on the strut towers, so I went with a new pair of moog springs instead, tubular K-member and A-arms
#60
#61
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
That is SWEET. How much did it slap your wallet for?
#62
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
looks great man, so far i just got the frame rails in mine. I got the s&w kit and its not extremely challenging like i thought it may be just time consuming. i hope to have it sitting back on the ground within the next month or so. i still need brakes, axles, and wheels/tires.
#63
Car: 89 Camaro rs.
Axle/Gears: 3.55
i deff want too. but for now i want to see how fast i can go on a 28x12.5x15 etstreet tire. i think the turbo setup should be fast with that and the good parts. but i will proably get bored just like i did with the s10 and do the edquay kit for the camaro. no doubt that is a great fitting frame. i do not like the cage thought. id proably make my own.
but if i keep seeing tubbe camaros im going to have to do it.
#64
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Damn, that is awesome looking! That shop definately does top notch work, it looks like they did a fantastic job with everything. That calls for the first LS9 swap!
#65
1 Post
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
holy sweet baby jesus! that is freakin sweeeet! and your serious about this being a 100% street car?
#66
Just 100% street, everytime I go to a drag strip I get hooked again. Looks like I will be using an all aluminium 572 ci, can you believe having all that cubic inch and weighting 100lbs less than the 305 it came with
#67
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
lookin good.
id still like to see wider wheel openings in the rear.
like red 406's build, but thats just personal preference i guess.
ill give you fitty bucks for it.
thats all i got.
#68
Fully intend to open wheel wells when the car is painted, I would rather have a body shop do those changes than a frame shop. Right now the tires I have on their don't rub and since they are not the pro's they don't grow. I have about 3/4 of an inch on both sides so their is no challenge.
This year is for motor and transmission, next year is for paint
#69
1 Post
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
how much suspension travel does a car like that have? looks like it'd bottom out pretty easy.
#70
Actually, their is lots of travel, we live in the pothole capital of the world. I have had no problem
#71
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
what is the back spacing of your rear wheels and the width of the rear housing and frame rails?
#72
#73
Just changed wheels, put on a 7.5 x 28 on the front and 18 x 30 on the rear, and added the Edelbrock strut tower brace, what a difference, it totally tighted up the front end of the car. Also did the AC delete to prepare for the big block coming in the next couple of months
#75
Car: 98 Camaro, 89 Camaro RS
Engine: 3.8l & 2.8l V6
Transmission: 4l60e & T5
Axle/Gears: Open 3.08 & lsd 3.42
That looks great. I wanna do that to mine lol.
I think your car would look killer with prostars or greg weld stars.
#76
Car: 82 Z-28 (Cert 8.50)
Engine: 416 LS3 / 1050cfm
Transmission: Powerglide w/brake
Axle/Gears: 9" 4.86, 4-link
That is one beautiful car, you should be pleased.....have you ever gotten around to measuring the frame rail and 9" width?...some one asked a few posts ago and my inquiring mind would like to know also...if ya' could please
#77
From the inside of the frame rails is 24" and the length of the 9" is 37"
#78
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Your diff is slightly narrower than mine. My housing is 40" and axle flange to axle flange is 45". I use 15 x 15 rims with 5.5" of backspacing and still have room to the frame rails that I could tuck the wheels in a little bit more with 6.5" of backspacing.
#79
I know I can put a bigger wheel under there as well, when they were moving it around in the shop they had a 22 inch wide tire under their, don't know the offset on those shop rims
#81
To do everything, and they supplied all the parts, with all the extra I had them do, about 14,000 Cdn to do the complete back half
#82
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
dude i want one lol.
id like to build one for strip only cause i just did a moser 9" and spohn rear suspension on my street car
looks good though man really does
and 14,000 canadian is how much U.S. dollar?
#83
#84
[QUOTE=572_Rat;4231010]Just changed wheels, put on a 7.5 x 28 on the front and 18 x 30 on the rear, and added the Edelbrock strut tower brace, what a difference, it totally tighted up the front end of the car. Also did the AC delete to prepare for the big block coming in the next couple of months
Keep us posted on the big block....maybe with some pics
#85
1 Post
huge rear tires, just freaking massive, and you say the little strut tower brace made a huge difference?
#86
572-RAT
the seats in your Car..who made them?
im looking(paid for fri last) at a set sorta like them.. But Marked
BOMZ Racing. in white. the seats are red w/black inlay
yours look sorta the same.. but with out the Logo..(diff color)
but the same shape. from Hyper Auto Parts/Hyperpomance Auto
$360 with rails shipped.
wanted to ask if ther are the same.. or what place did you get them from.
they look good in.
they look good in.
#87
I put the edlebrock 3 pt brace and it made a huge difference, going into corners even with the rack and pinion and the wonder bar and the largest spoon sway bar I was still getiing a lot of body roll up front. The strut tower brace elimanted it completely. We have some curving roads, with one bad corner, that 30 mph corner I took at 70 miles a hour with no body roll whats so ever
#88
572-RAT
they look good in.
they look good in.
These seats I bought from Jegs, Procar, seats were 124.00 each, but I am going to replace them with some Sparco's over the winter
#89
Car: 1987 Chevy Camaro
Engine: 383 twin 60mm turbo
What kind of rack and pinion did you get and is it manual or power?
#90
#91
1 Post
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
so are you getting the sparcos because those seats just suck? Or whats the deal. I was interested in buying those...super cheap. Let me know what you think about them
#92
Seats are fine for the price, the sparco set I was looking at will allow me to sit lower down
#94
#97
I live out of town, so I don't bring it in very much, I would like to do some of the cruise night but who needs the tickets
#98
Car: Soon t/b '84,'87 or '90camaro
Engine: 305,350, & 383 stroker
Transmission: 700R4 & T350
Axle/Gears: 373
I have the privelege of knowing you and look forward to not only becoming a good friend, but also one day having a close look at this car!!
Love the 3rd gens!!!
TTYL,
Ed
#99
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Will the 305 spin them big *** tires from a standstill Awesome ride man.
#100
