Camaro wheels with Blazer center caps?
Does any one know the GM or Dorman part number for the lug caps to hold the Blazer center caps on the Camaro Z28 15 inch wheels? I bought a set of the Blazer centers, but the lug caps are the long set. About an inch too long.... These are the ones in the pic.
Kevin
Kevin
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: Camaro wheels with Blazer center caps?
Those are nice looking, and better choice of over the stock caps that seem to fall off so easily.
Kevin
Kevin
1 Post
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
Are the Blazer lug nuts shorter? Maybe you need them. I have Astro center caps and lug nuts on my fullsize pickup and the lug caps are a lot shorter than the ones in your pic-those might work. Did those lug caps come with the center caps or are they the stock ones off of your GTA?
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
kah992
08-19-2015 02:55 PM
