Question on 17 X 8 with 255/40/17
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
I just bought a set of Chrome IROC rims 17x8 with 0mm offset and 4.50 backspacing. I have 245/45/17 on the car now and hate the look of them. They are too narrow and too tall. Looks like a pizza cutter wheel.
My question is could I run a 255/40/17 with only 4.50 back space and not rub in the front when turning? Or will I need to add a hub centric spacer of about a 15 mm?
Like this one?
http://www.autopartswarehouse.com/de...906150331.html
Like this one?
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Re: Question on 17 X 8 with 255/40/17
If you already have the 245s on the car, you should be able to figure out how much spacer -- if any -- you need for 255s. Just use a tape measurer and see how much space you have left with the 245s and the steering wheel turned lock to lock. I would bet that if you need any spacers you can use 1/4" non-hub-centric spacers from any parts store.
I had 17X8 ROH Reflexes with 275 tires and had no rubbing problems on my old '90 Firebird. I think they were a 5" backspace.
Pat
Pat
Thanks! I talked to the guy at my local discount tire and he went ahead and ordered the 255/40/17 tires for me and is willing to test fit them for me before I buy them. I think am going to pickup a 1/4 inch spacer like you recommended in case there is any problems or it is close but I think it will fit.
I measured my old BFG 245/50/16 on ARE wheels and they came in at 10.3 inchs wide using a digital microgauge. They are not supposed to be that wide but they are (I checked it three times with the digital guage). My 245/45/17's on the car now came in at 9.5 inchs wide. So if the 255's are around 10 inchs wide like they are supposed to be. They should just clear.
Car: 87 GTA
As long as you get the bs right, 255s will fit with no problem.
I've got 275/40ZR17s on my 17x9 ROH Snypers, with no rubing issues. I can't get my fingers between the tire & inner fender liner, but there are no rubbing marks. That's how close the tires are to the body.
