sway bar bushings?
Car: 1984 z28 camaro
sway bar bushings?
people keep telling me that the jingle under my car when i hit a bump or somthing is that my sway bar bushings are done for, what sway bar bushings should i order to replace my worn out ones? and i also heard its better if there polyeurothane or however you spell it
Re: sway bar bushings?
http://www.spohn.net/?action=product&pid=1152
The end links for front and rear are the same.
JamesC
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
James is right but just didn't say it, that metallic clanging jingle is your swaybar endlinks, not your swaybar bushings. The bushings last much longer than the endlinks do. Booth moog and trw make poly bushings(as well as rubber if you wish), and the prices are reasonable.
Cheers!!!
Cheers!!!
darwinprice
17
10-11-2015 11:51 PM
