A Question about allinment on my rear end?
Car: 1991 Camaro convertable
Engine: 305 T.P.I.
Transmission: 700 r4
Axle/Gears: stoCk
Hey all ive got a problem, i have a 1991 Z , i feel a vibration and i thing its do to my drive shaft of aliment, and i see only so many things that can move my rear end,, it looks as my driver rear traling arm is bent and my sub frame connectors are kinked a little. My hole question is i dont really see what hold eles holds the rear end in allinment??, welll yall have helped befor so thankx and i need a little more...
laer adaM
laer adaM
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: A Question about allinment on my rear end?
the only front to back alignment that the axle has is the control arms. If one is bent, then you need a new one. the panhard bar, it goes parallel to the axle behind it, controls the side to side alignment
1 Post
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
One more thing you can check is your torque arm,it sets your pinion angle,make sure your bolts are tight and check your mount/bushing to see what condition it's in.
oh, what subframe connectors are bent? pics?
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
