edelerock strut tower brace
Car: 89 TTA
Im having trouble with edelbrocks strut tower brace,my hood wont close!!!
It could close,but it would be flexing the hood a bit.do I have to remove my heat blanket under the hood to achevie that extra 1/8 inch of clearance I need? WTF in my opinon edelbrock sucks! If some one could post a pic of ther edelbrock strut tower brace on ther firebird/trans am please do so,any other input is much appreciated,thx
Car: 89 TTA
Re: edelerock strut tower brace
yes i mocked it up,measured it,followed the instructions precisley but...didnt check the hood clearance before I drilled,It seemed like a pretty straight forward install,honestly it think this would fit an iroc just fine because the irocs nose doesnt slope downward,like the firebird/trans am.
Im wondering if quality control @edelbrock let one slightly out of tolerance piece slip through.
I always use the search engine before I post,but ther was nothing addressing this exact issue.
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
If that is Edelbrock part number 5226 (for TPI cars), it says...
"Notes:V8 with TPI (tuned port injection). Some vehicles may require trimming of hood understructure."
http://store.summitracing.com/partde...5&autoview=sku
If you only need that 1/8" clearance, you could take a hammer and just tap that part of your hood in a little to make room. The heat shield you have should be able to cover the dent and no one would ever know... except for you of course... and the people that may read this thread.
Car: 89 TTA
[quote=racing geek;3703073]If that is Edelbrock part number 5226 (for TPI cars), it says...
awww damn...I wish i would have read that ahead of time,I guess it pays to do your home work before you but parts.thx alot man I really appreciate your reply.
Car: 1987 Firebird
Engine: 355
DO NOT HAMMER!!!
I had a slight fitment prob under my hood, for different reasons. The hood is basically made of all the same material, with slight thickness differences. When you hammer, your just gonna dent your hood.
Same thing happens, when you take a pair of pliers, or something and try to "twist it" into shape. It may work if you heated it up with oxy/acetylene, but not as it is.
Dont ask me how i know......
I would recommend taking a grinder, or a dremmel tool to it, and just grinding away the peice.
You can cut out alot of the "structure" though, and nothing should happen. Thats basically what the factory did for the formula, "power bulge" cowl hoods. They just cut away large chunks of the structure, and the hood worked fine.
1 Post
Car: 1987 IROC-Z
Transmission: TH350
DO NOT HAMMER!!!
I would recommend taking a grinder, or a dremmel tool to it, and just grinding away the piece.
Online170, I noticed you have an RS so I would like to know if you have tried the Edelbrock 5226 STB on your car. Will it clear camaro hoods? If it clears the plain stock hood, I'm sure it will clear an IROC hood... right?
Car: 1987 Firebird
Engine: 355
That's good to know. In that case, XxCoLTxX, I wouldn't use the hammer method.
I just had a clearance issue in my firebird with the hood closing, because of my holley DP carb, and the edelbrock RPM intake.
So i went through the trouble of getting a flat hood, and cutting a hole in it, so i could close my hood. I almost kicked myself, when i realized, that i could have gotten away with trimming part of the hood structure rather than cut the entire part out. I also tried the hammer before doing any cutting, and even some pliers, but i was just denting the hood from the inside. (i didnt care about my paint, but you might).
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
edelbrock brace on my 83 ta with powerbulge hood. no hood clearance issues but it touches the c/c plates so to align it u have to remove it.
1 Post
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
I have the tpi version on my camaro but I do not have the stock hood. I have a cervini's cowl hood and it clears with no modifications.
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
I had to remove the heat blanket and cut some of the under structure out of my 87 bird to get it to fit. What I did was lay masking tape upsidedown on the strut tower brace and gently close the hood to see what sections needed removed. But Edelbrock still sucks, I did not want to cut anything.
Car: 89 TTA
I really dont wana cut the under side of my hood,Im thinking about notching the strut tower brace on a lathe,then repainting it.honestly id rather have a small dip it my bar then cut on my car. Ive seen the BMR brace,It fits very nicely with no mods.
Car: 87 GTA
Instead of cutting the hood or STB, you can shorten the 2 mounts by the strut towers, thereby lowering the cross piece, if you have the room to do it between the plenum & STB of course.
Like this...
Maybe between removing the insulation you can gain a 1/2" there, then shorten the mounts themselves and gain another 1/2"? For a extra 1".
Like this...
Car: 89 TTA
Yeah,thers not enough room,my L98 tpi sits a bit higher then your Ls1(very nice btw)Ive removed the heat blanket,Ive already shaved the mounts like yours and elongated holes on the lathe so that the stb can actually sit on the plenum,of course I wouldnt mount it that low,but I wanted to check to see if it would close and it does,but... you can see the hood is sitting higher then the fender,therfore its still hitting...thus my only 2 options besides cutting my hood is lathing a section of the bar..or getting a Ls1 dropped in,LOL
these realy wernt ment for the firebird style car,edelbrock prolly had a camaro for mock up when they fabbed this piece for mass production...
Car: 87 GTA
That's not my LS1. A local guys red 92 Z. I'm still sporting my white 87 GTA. I'm fixing to get an Edelbrock STB. If it hits, I guess it'll stay off until my new fiberglass hood comes in.
Car: 87 GTA
With a new hi-rise hood though, wouldn't there be no problems? If so, no big deal.I'll have an extra 3" or so.
Car: 89 TTA
the stb only hits a small part of the under hood skeleton,and only on the drivers side,It looks to me like a 2 inch section of the hood frame needs to be cut,I imagine formulas have no problem(has stated earlier in this thread),and your high rise or any cowl hood should work great
1 Post
Car: 1987 IROC-Z
Transmission: TH350
Ok, this is for all the people that posted about the STB fitting their camaro with an aftermarket hood... do you happen to have a stock hood you could throw on to see if it will fit? I would like to get this but I don't want to cut up my iroc hood.
I have a Edelbrock STB and it fits fine. The two braces that run to the cowl need to be mounted on the bottom and not the top. Will post pic a little later
LT1Formula
10-08-2015 08:34 PM
tcflint
09-27-2015 05:58 PM
