Rag Joint Replacement... Gory detail inside
Car: 1991 RS Vert
Engine: LO3, 305, TBI
I'm in the process of doing the front suspension/steering on my car.
So far, I replaced all the steering components on my car: inner and outer tie rods, UMI tie rod adjusters, idler arm, center link, and sway bar bushings and end links. Ball joints, coil springs, camber/caster plates, control arm bushings, and new tires are in line for the next couple of weeks.
I had it aligned after I did the steering parts. I went ahead and got the "lifetime" alignment from a local shop. I figure I'll soak them for 4 or 5 alignments before I'm done. The tires are 11 years old, so I suppose I could have waited until I was finally done with the front end before getting new tires and an alignment, but I figured I would do it piece-meal and still be able to drive it around.
Anyway, after the alignment today, the tech stated there was some play in the steering. It was considerably tighter than prior to the steering component replacement, but still a bit of slack. I'm sure the steering box is wore out (like the rest of the components) but I decided to replace the rag joint first.
So, here it is:
1. Disconnect the battery and unplug the airbag connector near the steering column. It is under the dash. Remove the lower dash cover and look for the yellow wire that is marked SIR - supplemental restraint system.
2. Remove the bolt on the rag joint that goes to the steering box and pry it out.
3. Remove the bolt and nut on the shaft near the firewall (near the brake booster)
4. Pry and fight the shaft out of the car. The brake lines get in the way and space is tight. However, it can be done. The shaft collapses so that makes it a bit easier.
5. Drill out the rivets and remove the old rag joint.
6. These were odd rivets. I used a hacksaw to dispose of them.
7. Here's the new rag joint. Notice it is a bit bigger and a bit thicker than stock.
8. I pulled the sleeve back on the shaft and filled it up with some lithium grease. It didn't help much, but I figured it couldn't hurt.
9. I got some new bolts, nuts, and washers and assembled the rag joint.
10. This was the monster. The coupler bolt and the rag joint bolt didn't want to play nice. I ended up going in the other direction with a regular hex head bolt. I had to pry on it to get it to slip over the collar but finally got it on.
So, what should have been about a one hour job ended up being about 4 hours. That includes two trips to the hardware store (and a beer stop...which might partially account for the extended length repair...).
The result: not much help. The old rag joint was 17 years old. It was only slightly more "sloppy" than the new one.
The steering still has some play in it. I plan on replacing the steering box in the near future along with the rest of the upgrades.
My suggestions:
1. Get one of the "rag joint eliminators" discussed on the forums here. They might transmit a bit more road vibration, but I don't think it would be too bad.
2. Buy the whole shaft assembly (if available) and bolt it on in about 2 minutes. If you can buy it for $100 or less, it will be well worth the money.
I hope this helps.
Trick414
So, here it is:
My suggestions:
I hope this helps.
Trick414
Re: Rag Joint Replacement... Gory detail inside
Trick414,
Thanks for the detailed write up and pictures. I'm about to do the same job and this will help out a lot. BTW, did you use the HELP! brand part number 31002 rag joint for this job?
Ray
Ray
Car: 1991 RS Vert
Yes, it was the HELP! 31002, about $10 at Autozone.
Car: '91 TA vert
Engine: turboLSx
For all the hassle, I would've just done the eliminator. Oh wait, I did.
At least now it'll be easy to replace next time!
Car: Pair of 92 Z28s
Yup, i got the rag joint eliminator. I love it, took out a lot of slack, was a big improvement. Comes with new hardware and instructions pretty straight forward, taking out the steering shaft took me longer then actually installing the rag joint eliminator.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I have the new rag joint in my car right now, and had planned on doing it this weekend. But, I've heard the rag joint eliminators cause a spot in the steering to bind or to have an odd feel. Is this true?
This is the first time I've heard of this repair/upgrade.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
A lot of the play in the box can be taken out by properly bench adjusting it. Looks like you need a seal kit for it anyway, 'bout $30 at AZ. I've not had any luck with reman steering boxes myself. In the end putting a kit in my old one or a used one and properly adjusting it always worked better.
Car: 92 RS
Engine: 305 TBI
Axle/Gears: ??
i dont wanna be a threadjacker, but i just bought a repair kit for my box, it is an "HX", and replaced all the seals, i had a hard time putting the darn ***** into place, and now what is really killing me is how to put in the adjusting screw/plug cover, the one with the 4 screws, it goes in a few turns but then it kinda locks too tight and i dont wanna force it in so i dont strip it, do you have any suggestions on how to do this? thanks in advance!
Is this the aluminum top cover for the pitman shaft? If so, you'll have to ensure the rack is centered and drop the pitman shaft in from the top. May have to turn the shaft slightly to keep it from hanging up until it slides all the way in. Also make sure you have the adjusting screw (allen head on top) all the way out.
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Car: 92 RS
Engine: 305 TBI
Axle/Gears: ??
And to everyone just FYI I tried replacing the rag joint but there was way more slop than with the old one, so i just replaced the whole shaft with one from a pretty good donor at the local Pick'n'Pull. In the next days I am gonna try to order the Rag Joint Eliminator for a better result.
I recommend (4) 5/16"-18 button-head bolts, 1.5" long. I only used 2 button-head bolts and 2 hex-flange-head bolts but would have liked to go with 4 button-heads. The button-heads provide a little more clearance. Oh well, it should be ok.
Car: 1991 RS Vert
Those button-head bolts look like a pretty good idea.
So, they "grabbed" good enough to crank down the nuts?
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
If anybody wants to give it a shot, I'll make you a deal on my old one.
Had to use the tool to tighten them, inverted hex or whatever it is, along with a 1/2 inch wrench on the other side. Its not like a lagbolt where you can't get a tool on it at all, can't really tell in the pics I posted though. It has something on the head to tighten it.
Guest
Posts: n/a
I had a very bad tight spot when I used the rag disk eliminator. the aluminum dixk will cause bind is some cases. I have an '87 Camaro with a quick steer 12:1 box and I had bad bind. I when to a borgeson joint aftermarket type shaft and the bind went away with the two pivot points rather than one pivot and the rag joint (or one entirely once th erag joint is eliminated.
http://www.cardomain.com/member_page...2_150_full.jpg
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
skinny z
10-05-2015 06:23 PM
bubbaz28
09-18-2015 02:09 PM
