Upper Strut Mounts & Bump Steer Kit
Car: 1985 IROC
Engine: 305 4bbl H.O.
Transmission: WC T-5
Are new USM's and a bump steer kit really necessary when lowering a car 1" front and rear?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Upper Strut Mounts & Bump Steer Kit
no not really
Car: 1985 IROC
not really, but highly recommended? the setup will be koni yellows and eibach pro.
if you are looking to get the most out of the suspension, then yes they would help. are they needed for the changeover, no, unless you race the car you probably wont even notice a difference.
New strut mounts may be a good anyway just because if they are still stock chances are they are worn out. bumpsteer kit is not a dire necessity, but like i said, if you are looking to squeeze every last bit of performance out of the car, then the bump steer kit will help you in that quest
Car: 1985 IROC
Thank you very much for the info, I suppose I'll have to find me a set. Are there any that you recommend?
hotpart.com sells a good adjustable strut mount, and Spohn performance also makes good mounts, theirs are taller to allow the strut to retain its full range of travel even in a lowered car. I have had both, and currently use Spohns.
Car: 1985 IROC
Thanks again! I'll go take a look at both.
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
ambainb
04-25-2016 09:21 PM
Thirdgen89GTA
08-20-2015 03:11 PM
