Where to cut rear springs?
Well I searched through the suspension forum and found lots of threads about how to cut rear springs and how much drop you'll get, but I didn't find an answer to this question:
I have two sets of rear springs, both having the progressive wind on opposite ends. So which set do I cut? The set with the progressive wind at the top or the set with it at the bottom? (top being car, bottom being axle)
I've read Strano Performance only sells linear springs because it helps in tuning the shocks. I have Spohn's coil over, single adjustable QA1 rear shocks.
Thanks guys.
Thanks guys.
Re: Where to cut rear springs?
you don't cut the pig tail end ever because it wouldn't fit on the rear end mount then. You'd cut the big end, I knocked off 1/2 coil and removed the rubber isolator on the spring top and just used 5/8" heater hose around the entire top coil and was able to get a 2" drop or so out of it for 15 minutes of my time.
Sorry I must not have been clear enough. I'm going to cut the top of the springs where they meet the car, but one set of springs has the progressive wind meeting the car and the other set has the progressive wind meeting the axle. I'm sure there is a difference in cutting a 1/2 coil of progressive wind rather than a 1/2 coil from the linear section. I'll try to get a pictures up.
1 Post
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
You shouldn't cut either set. Never cut progressive rate springs. You lose the progressiveness.
Think about it. When you cut a coil, it makes it stiffer. You increase the spring rate. If you cut the loose part, you stiffen the stiff part more. If you cut the tight part, you stiffen the loose part.
In short you'll have an unballanced rate of progression.
Find some stock springs in the bone yard to experiment with. Then if you want it stiffer in the back, get a good quality lowered spring.
Exactly, I want to lose the progressiveness from the spring. This is what Strano Performance advertises for his springs;
"Linear rate front, linear working rate rear because actively progressive rate springs are not able to be damped properly due to the variation in rate. You will not find progressive rate springs on serious performance cars, and never on race cars."
It makes sense to me to cut the progressive coils out first. Does anyone agree?
1 Post
In that case, cut the springs with the tighter coiled ends on the top. That will give you a more equal constant rate spring.
ambainb
04-25-2016 09:21 PM
sailtexas186548
08-26-2015 03:32 PM
TA8487
08-11-2015 09:02 PM
