tired of spinning. lakewood 50/50s worth it?
#52
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: tired of spinning. lakewood 50/50s worth it?
he was bumpin his stereo too loud.. LOL
****, whats your suspension look like?? i'm barely pullin 1.6xx with 28.5x11.5-15 qtp's.. but i will give you the weight factor.. much more friction at the wheels then my car which is almost completely stripped.. (too lazy to reinstall the carpet and panels dont fit with a roll cage)
#53
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
the track was dead and i was hot laping, running my fans and bottle heater. when i let the car sit in the lane for a few minutes with the fans running it would draw the battery down and make my nitrous act up. the solenoids wouldnt stay open down the track. when i let the car charge with the fans running and heater on it was fine. the car stayed around 200-220* all day.
#55
Car: 1984 Trans Am
#56
Car: projects.......
#57
- All homemade motorsports suspension sir. I'm a fabrication nut. Poly bushed box lower control arms, relocate brackets, 3/4 black iron pipe adjustable tq arm mounted to a crossmember that tied to my "in-floor" subframe connectors. I was running -6 pinion angle and about 1 down on the control arms(low to the back). IIRC, my tq arm was around 54" which was obviously too long for my power level since I needed -6 pinion angle. Monroe sensa-junk shocks and eibach sportline springs.
The biggest thing everyone seems to forget is that no tire truely "hooks". It's all about controlled spin. - The T5's I was running came out of mid 90's v6 birds, thus they had that ridiculously low 3.75 1st gear. Slow your wheel speed down, controll the spin better. BUT, you're only faster if your motor will twist up fast enough to take advantage of it. - I'd bring it up to around 5600 in the beams, then stand on it and side-step the clutch, depending on how it felt, I shifted 1-2 between 72-7600, 2-3 & 3-4 usually around 67-6800.
Hotrodboba400
12-10-2019 07:07 PM
2MNYMaros
09-15-2015 11:36 PM
