pro kit?
1 Post
Car: 1989 Camaro IROC-Z
Engine: Lt1
Axle/Gears: Quick performance 9" 4.11
pro kit?
I need a favor from you guys. I have hooker super comp long tubes and currently I have about 3.5" of ground clearance with them. The car still has the stock springs and I know for sure they are worn out and the car is lower than stock. I'm pretty sure I'll only lose maybe another .5" or so with the pro kit but I wanted to know what height you guys have from the ground to the center of the fender. Here are some pics I took:
front:
rear:
front:
rear:
Re: pro kit?
sportlines would drop that a good bit more but i think even the prokits gona drop that alil still. u gotta be careful, your exhaust is gona get real low quick.
im running sportines and i have 25 3/4" front and 26 3/4" rear
with 17" rims and 245/45/r17 nitto 555 rubber
Car: 1984 Camaro Z28
Engine: Blueprint 383
Re: pro kit?
I'd go measure but my 84 Z28 is up in the air right now.
I put my pro-kit on when the car had 220,000 miles and it ended up dropping the car around 1.25" at each corner.
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
Re: pro kit?
isolators are those black rubber things on top of the springs some people remove them and put heater hose on top. also know as the "heater hose mod." its a cheap and effective way to lower your car.
Re: pro kit?
yea thats the prob i had with it. i still put the isolators back on when i did my sportlines... and i still got that height i posted above. if i took out the isolators i would have dropped an extra 1/2" and when i tell u its low already.... i cant even get an iron jack under my car to jack it up, i have to start with a low profile aluminum race jack lol. i have true duals, headman LT, 3"xpipe, with 3" boxed force mufflers and turndowns and i would have never made it if i didnt modifly the undercarage alot. still the mufflers are kinda low but i'll be fixing that in the spring.
the sportlines are the safest lowest drop in my opinion. other kits lower more but i cant see how my car could get anylower... my kmember is like 3-4" above the ground lol
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
