View Poll Results: Which subframe connectors for my daily driver?
Voters: 68. You may not vote on this poll
SFC's Alstons or UMI?
#152
Re: SFC's Alstons or UMI?
Seems im not the first with shipping issues, atleast he made it right for that guy, problem very similar to mine.
https://www.thirdgen.org/forums/afte...?highlight=umi
Again, I apologize for the shipping delay.
No matter a company does they are going to have mistakes here and there. That issue was almost a year ago, a few issues a year is common with any larger company. We ship 150-200 packages a week, for a few a year to get mixed up is still over a 99% accuracy.
Again I apologize, But I am glad you like them.
#154
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Looks good. The black color really hides them nice. I was thinking of spraying mine with flat black eventually, just because they are so visible.
Any luck on installing them yet?
#156
Engine: LO3
I posted this picture earlier in the thread, but I will put it again for you here.
Anyhow, the trick is to get the main SFC in place, then stick the little piece over the exhaust and on top of the main sfc. Then, slide it forward or backward, untill it is tight with both the subframe and the connector. Probably more forward like mine. Then, mark exactly where it needs to be welded to the SFC.
You really should weld it off the car. I didnt, because we didnt have the resources to replace exhaust flanges just to drop the pipe. But if your exhaust is newer, you should be able to get the whole y-pipe out, and the catalytic pipe too. That will give you room to lift it in place all as one part. Just like the driver side.
Also, when you put the exhaust back on, you might be able to put a little more slack in the hangars to lower it some more. But it probably should fit fine unless you are running dual cats or some massive pipe.
#158
Engine: LO3
If the y-pipe is all one piece with the test pipe and intermediate pipe, I would just un-bolt it from the header flanges. Then, slide the hangers off and it should drop down. No need to un-do it from the muffler, because there is plenty of play back there. Even if it only rotates down a little ways, that should be enough room to lift the SFC in there as one piece.
#164
Engine: LO3
No, but I was thinking about it. I figured it wouldnt be strong enough to hold up the shear weight of them.
#168
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
From the rear, under the car. I'm on jack stands doing an axle swap and front end work. My SFC's are just a little lower than the GFX, but the exhaust is actually lower.
#170
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I would think that SFCs would help creeks more than rattles.
#171
Engine: LO3
Damn. Looks nice on yours.
Also, lemme know how it held up to the floor jack test.
#174
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
hey camaropunk, that a pretty clean looking car you have there
I would definitely get some paint on those welds if you haven't already done so
#176
Car: 92 Firebird vert
Engine: 388ci
Axle/Gears: 3.23 open
I just had my alstons installed last saturday at a local muffler/welding shop. Round, square, zee channel, alstons, umi or briggs and stratton all I can say is WOW. I could tell the instant that I backed off of the lift. My car is a vert, and they made a huge difference. I recommend SFC's to everybody that has a 3rd gen.
