cragar ss 17x11
cragar ss 17x11
hi,
I was looking at 17x9 front and 17x11 rear cragar ss 612 series
would these fit an 84' camaro?
and can i put 275/40/70 front 315/40/17 rear tires on there
like BF goodrich g-force t/A-kd's
thanx
thanx
Re: cragar ss 17x11
I swear to Cod someone needs to make a 3rd Gen wheel by brand and model compatibility chart.
KTS... Basically, you have to read the sticky at the top of this forum and do some measuring. Do you have stock brakes? Have you lowered the car? Factors like this affect your answer.
In short, I don't know.
Good luck and welcome to the forum! We require pics!
1 Post
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
Re: cragar ss 17x11
the front will fit depending on backspacing etc if u need spacers are not but the width is np. The Rear thats a diffrent story will 17x11 fit stock wells... no. Can it be done.. yes. There are a few ppl on this forum running 315's in the back but they usually stick out a good deal and it required wheel well manipulation. Adj panhard bar and lcas. In my opinion the fattest u can get back there without a whole lot of labor into it is 10.5 with a 295 tire. Use the search tool thou theres tons of post on will 17x11's fit and such.
Car: '91 TA vert
Engine: turboLSx
Re: cragar ss 17x11
Re: cragar ss 17x11
can you tell me what kin of spacers I need
the rear backspacing is 4' on these rims
the front is 5,25'
does anyone know if 13' brake rotors fit the wheels
the front is 5,25'
88SS6SPEED
11-11-2015 07:05 AM
