jegster torque arm?
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
jegster torque arm?
is the mount for the floor right under the center console? i was under my car tonight removing the old arm and driveshaft and i just eyeballed it and it looks like its right under the console. am i right? if so this is gonna suck.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: jegster torque arm?
thats about where it is, why does it suck? the console is not that hard to remove, nor the seats.
ahh, carpet could be interesting
Car: 86 camaro
Engine: 385
Transmission: glide
for some reason its always a pain to remove my console dont no why.i also have a cage in the car that might create a challenge. oh well im putting it in tonight. we will see if it was worth it on friday.
1 Post
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
tell us if it was worth it or not, i used an energy bushing on my stocker and it made a diff, im fixin to pull my stocker and weld up some rolled steel bars up and down it to make it stronger, clean it up and paint it with some engine paint, im planing to my own pan hard rod and the conecter that goes from the pan hard to the sub frame also, i just like building it my self, just nice to say i made it my self and it works good lol........ but i think i will have to buy some lakewood traction action bars.....lol the seem a little hard to fab up unless someone knows some trick i dont!!!
1 Post
do you think the rolled steel bar will work to make my stock arm tighter?? im using a real good bushing? im runnin the bar down the top and bottom and making connecters from top to bottom with it.... the steel bar im using is super strong, kinda like rebar but no ridges, a little bigger, and harder to bend.... im using black iron pipe on my panhard rod with end links off of a 3 point hitch for a tractor (the adjutable type), will prob use black iron pipe and the end links for my control arm since you think the traction action bars aint worth it, but i got to beef it up, my trans shifts so darn good, i need to make the rear alittle bit more secure LOL, now just need to figure out if i want to advertise i got good parts by painting them chevy orange or red motor paint or just painting them black
Car: 86 camaro
Engine: 385
Transmission: glide
got it in. it was a pain. had to raise and lower the lift about 10 times. and remove the bar 4 times. havent put the interior in yet but it wont matter because i only have half of an exhaust. i had to cut the driverside off before it goes over the axle. just need to modify it a little and it will be ready again.havent set pinion angle yet.
Car: projects.......
xx11seczxx - should be a very noticable improvement - be sure to post your results.
89RS_82Z - the traction action bars deffinitely suck. Poor design. - As 86TA stated, just go with tube control arms and a good torque arm. - As for your DIY, I wouldn't use solid bar stock, bend wise it's weaker than pipe. I went 1.66 60fts on a 3/4" black iron pipe torque arm, but it was a full build, not just bracing. You should really think more about buying/building a complete arm, as the pinion adjustability is probably the biggest part of the gain, the second gain being divorce from the trans. IMO - use 1" pipe for the tq arm, 1-1/4" for the control arms(basing off of black iron I.D. sizing). For street tires, atleast one-end poly mounted.
1 Post
Shagwell ..... did you use the end links for a tractors 3 point hitch on your control arms and your panhard (if you built a panhard) or did you use something else like the rod ends in jegs?
not sure about building a total custom tq arm yet or buying one, as the car is not raced, i just want to tighten it up a little, now that it was mentioned if i do decide to beef up a stock one i will use black iron pipe and run up and down braces like so /\/\/\/ if possible. im going to the local U-PULL-IT and using junk yard parts for templates, and if i do the tq arm i will moddify a junk yard one as to not possibly destroy my factory one, as i said its not a track car so i dont think the work involved to do total custom or $$$$$ for a all ready built one is worth it............ unless you guys think that the cutom built or all ready made one is worth the time or money on somethin that isnt running at the track
yea please let us know how it works out and the diff it made. i have one i got used and i repainted it im putting it in when the new motor goes in...in the spring and i havent heard anyone post results. its the only peice of the rear suspension i havent upgraded even tho i added a poly bushing to the stocker and i def felt improvment. so it should be noticeable.
as far as fabbing up your own LCA/panhard rod. i posted a thread in Fabrication about 2 months ago, it still there wthin the first 2 pages on how to fab your own up to be stronger than most aftermarket and lighter than stock.
i used thick wall mild stell tubing and it really only cost me about as much as the poly bushings cost me. demensions etc are in the thread. wasnt hard to do and these things are STRONG! i upgraded my handmade panhard rod to a UMI adjustable when i lowered mine but other than that, improvements over stock where incredible.
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I just put one in with my new engine.. I really like the difference it made, bites a bit harder out of corners and just seems to give the car a bit more traction off the line too. On the bad side for me in fourth gear it transmits a bit of gear whine I didn't have before.. My car will never see a strip however so these are SOTP observations.. Though IHI here on the board can give a strip opinion of the arm.
My main reason was getting the darn thing off the tranny and preventing the frame tearing folks have had with the t56 from the levering action on the crossmember.
all in all I would say it is a very good mod. Be happy you had a lift, I was on my back with jackstands.
Car: 83Z28 HO
Transmission: G Force 5 speed
I tried the Jegster arm on mine, and there's no way it would've fit without major grinding on the torque arm bracket...it was angled waaayyy off.
Car: 86 camaro
Engine: 385
Transmission: glide
amen to that. mine was a royal pain. i had to oblong the holes to make mine bolt up. still havent set pinion angle and that was like 4 hours. interior isnt back in yet either. but im also running wires under my carpet.
Car: 86 camaro
Engine: 385
Transmission: glide
is this torque arm supposed to resonate noise or is it only my car? rear end is very loud. trying to set pinion angle and dont think im doing it right.
It might be whine from the rear itself, my exhaust is too loud to notice other noise, but an improperly set pinion angle could make this more apparent as well.
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
That would figure since the arm is now bolted to the floor pan/tunnel! Any vibration would be transmitted to the cabin.
Car: 83Z28 HO
My rear section of the jegster torque arm bolted on in under 5 minutes with no issues. Yes it was angled way off, but that's why it's adjustable so you can set pinion angle properly. A lot of that depends on ride height since it's bolting to the floor so ride height would affect the initial pinion setting.
I can only guess that you have some older style Moser TQ arm mount or something.....because if you seen the way the Jeg's arm bolted to my Moser rear, it would be pretty obvious that it isn't a "bolt-in" proposition by any stretch.
Car: 86 camaro
Engine: 385
Transmission: glide
i no my arm hit the floor on the drivers side in the back. a little hammering and its clear.
Car: 86 camaro
Engine: 385
Transmission: glide
thats about the same with mine. about 6 months old but ive got a 12 bolt not a 9 inch.didnt bother me to hammer it in. im at the point were i dont care i just want to hook.
Car: 83Z28 HO
The crossbrace on the TQ arm butted up against the "nose" of the Moser TQ arm mount, but wouldn't pass over the nose throwing the angle off if that makes sense...I ended up grinding the nose down for an hour on that heavy casting just so my UMI non-adjustable would fit...
xx11seczxx
I already responded in your other thread.
1 Post
cool, im going to start on mine after the holidays, i guess this will help alot on making it more stable on that 1st to 2nd shift, i know the energy bushing and tranny mount helped loads on that, i guess the control arms will firm it up some more, correct me if im wrong
Car: 85 Firebird
Engine: 468 BBC
Transmission: Turbo 350
Axle/Gears: 3:73
Anyone have a write up on the install of one of these jegster arms ? -- What about install photo's
Car: 91 Z28
Engine: 5.7 TPI
Transmission: 700R4 Probuilt Hardparts
Axle/Gears: G92 3.23
i'm installing mine now, tomorrow, tonight.... one day at a time. it's pretty simple, but I want to see some pics of the tunnel mount plate. i've got a 4th gen aluminum driveshaft, concerned that it wont clear the torque arm and also, since i havent sized it up yet, just wondering if the mount covers where the ebrake comes through the tunnel.
I've got the instruction sheet if anyone is interested. I reallly want to see a pic of one installed... particularly the mount in the tunnel and the arm itself.
Car: 91 Z28
Engine: 5.7 TPI
Found a pic on webshots... stole them from a fella' with an early thirdgen camaro.
install is simple... 3/4" spacing on the slider (at the front) with the grease nipple down and load off vehicle. THen, load the suspension with creative jack stand placement and verify that the 3/4" is still between the head of the slider and the torque arm itself... exposed 3/4" I suppose from the pic. Drill, mount, torque and test pinion angle. Instructions say 5 threads showing on bottom, each side; 3 threads showing on top. thats a start, but will need angle finder to adjust properly. Should be able to plant hardcor e after that. Thanks for the pics, whoever. Looks like a 4th gen driveshaft will clear, and the ebrake comes out underneath, where it is not touching in a bend of the tunnel mount.... see for sure when it goes in this week.
http://image63.webshots.com/163/1/82...4drOEBf_fs.jpg
http://image52.webshots.com/152/8/91...4hKjluE_fs.jpg
http://image44.webshots.com/45/7/36/...4fcrgkL_fs.jpg
http://image46.webshots.com/46/0/2/3...4mkdfQU_ph.jpg
http://image46.webshots.com/46/6/65/...4KXjfSy_fs.jpg
http://image48.webshots.com/48/2/84/...4WsbdKh_fs.jpg
nightrider327!!!!!!!!thanks again!!!!!!!!!!
1 Post
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
So, any more thoughts on the Jegster torque arm? Pics maybe? The post above mine just says "forbidden" when I click them.
Car: 1988 Camaro
I'm using the adj. jegster torque arm and love it. Been using it for about 4 years now. So far best 60' times are in the low 1.60's with it and many other aftermarket parts.
Heres my pics of it on the stock 10 bolt rear
http://rides.webshots.com/album/551082180CMaOxC
Theres a couple pics in this album of it on my moser housing 9" ford setup on same car
http://good-times.webshots.com/album/561702598OdsQff
1 Post
Engine: 2002 SS LS1
Thanks for sharing the pics. Great looking settup. It looks allot better than my Sphon settup. Really feels in the way with the torque arm going to the crossmember, and the crossmember hangs really low and scraps on speed bumps.
I am not looking for a Cadillac ride but do you feel a lot of drive live vibration with the Jegster arm?
Car: 1988 Camaro
Now I have alot of driveline vibration, stiff ride, etc but its more due to the roll cage, sfc, stiff springs and shocks than the torque arm, plus the dual 3" exhaust pipes touching the floor pans, trans crossmember, etc
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
I know it is an older thread but had a quick question. Why have slider 3/4" out when installing it without the rearend under a load and then put it under a load? Couldnt you just install it 3/4" out when the rear end is held with jack stands? Not sure of the first part and why you would position it with the rear end not at ride height and then bring the rear to ride height? Thanks guys!
no green
01-09-2016 09:22 PM
darwinprice
17
10-11-2015 11:51 PM
