Greasable vs. Non-greasable Bushings
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
What are the good and bad of each?
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Greasable vs. Non-greasable Bushings
only bad thing i can think of against greaseable bushings is having to buy a greaseable bracket to put them in.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Which bushings are you talking about specifically?
For example, LCA's, if you get greaseable, the arm should be made to accept the bushing, so you shouldn't have to modify anything.
No real downsides. It's more expensive because it's an added desirable feature. Helps to reduce the tendency to squeak.
come to think of it, the only bushings IIRC that have seperate brackets would be your sway bars.
so my point is moot, lol.
camaro1185
10-26-2015 06:51 AM
