Are koni sports good handling shox
Car: 88 iroc z
Engine: 350 tpi
Axle/Gears: stock
I found a package online to get a set of four koni sports and four eibach pro kit springs. I was wonder if those are any good for road handling. If not what should I get. My cousin has a saleen mustang and I didnt want a for out handling me.
Car: 88 iroc z
Engine: 350 tpi
Axle/Gears: stock
Re: Are koni sports good handling shox
the url is http://www.shox.com/appguide/shoxsho...ctsdisplay.php the very top one
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
koni sports, the yellow adjustable ones, are great shocks, probably the best you can do for an over-the counter part. though they are not cheap, usually 250 and up each for the fronts and about 200 each for the rears
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
They aren't the best you can buy, but as far as I know they are the best in the sub-$2000 catagory. I have KONIs and Eibach on my car, and while I want to replace the springs, the KONIs aren't going anywhere for years to come. The cheapest I've found for the Yellows is 226 per front and 105 per rear. I'd say with shocks springs and the right tires, you won't have any trouble dusting him.
from what ive seen and heard, the bilsteins are for ride quality and the koni's are for performance
Car: 88 iroc z
Engine: 350 tpi
Axle/Gears: stock
Well then i might get the konis for the performance
Car: 1991 RS Camaro
The Bilsteins are also a performance shock, but not as much so as the KONIs. And, they aren't adjustable. I've set my KONIs to full soft all around recently after having them set about halfway since purchase, and I have to say that they are a comfortable ride in most circustances. On really uneven road with lost of patches/potholes, you'll know they are a performance shock and you're not in a Caddy. But, on the highway at high speeds or for high speed cornering, I wouldn't have anything else.
I don't think the KONIs would be 'harsh' on a stock car. More stiff than 18 year old worn out stockers for sure (or even replacement stuff from AutoZone), but the gains in cornering and controlability would, in my opinion, greatly outweigh the slightly stiffer
Car: 88 iroc z
Engine: 350 tpi
Axle/Gears: stock
do you think the konis and an eibach combo are equal to a coil over suspension
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Yeah are Spohn's coil-overs worth the extra $300-400 more than the Koni Yellows? What are the differences?
Car: 1991 RS Camaro
I don't know. I've never really read anything on them vs KONIs. From working on my friends Integra, I know coilovers are PITA compared to what we have. I'm sure there are some advantages to a conventional set-up, but for the extra $300-$400 you could get a posi rear end with disk brakes.
I picked up a 4th gen 3.23 posi with disks for $300.
the coil-overs actually sit ON the struts, so you have a Koni sport strut for example with a coilover setup on it, so you need to buy both, so it get expensive, a benefit is they more the roll center out further, and they adjust quite easily
Car: 1991 RS Camaro
Front KONIs+ front coilover = about $1100....ouch
Looks nice though. That does look alot easier to adjust than the Ground Control weight jacks I was looking into. Still hella pricey though, and the rear still isn't height adjustable. I may try it sometime (in the distant future) though. Wonder if the rear coil overs work with KONIs...
the rear coil-overs are fully adjustable in height and vavling and they come with shocks
Car: 88 iroc z
Engine: 350 tpi
Axle/Gears: stock
would the konis and eibach kit be able to handle like a corvette, or would you need sub frame connecters strut tower brace ect.....
Car: 1991 RS Camaro
I've just heard bad things about QA1`s for handling is the reason I was wondering about the rears.
Depends on the Corvette. C5 and C6 Z06s would be pretty hard to beat, but most C4s (maybe base C5s??) and before would be beatable with KONIs and springs. SFCs should still be installed on the car though. Most agree that they should be installed on the car even if you only plan to use the car as a commuter. I really need a set.
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
I have the Koni yellows and Eibach pro springs package(from Shox)together with some other goodies like Lakewoods rear end stuff and Edelbrocks strut tower brace polybushings in chassie and runs on pair with original slightly modded Porsche 944S/Turbos around short cone tracks,i am not a good driver so not bad for such a hwy car.
I have the back set to middle hard and the fronts i have in softest while in highway mode and on the track i set the front to hardest works nice.
But over here in Europe we like our cars rather stiff,maybe thats a bit to hard for US roads overall no problem on the highway.
regards Mats
regards Mats
ambainb
04-25-2016 09:21 PM
LT1Formula
11-16-2015 01:13 PM
NBrehm
08-25-2015 11:49 PM
