255 or 275's on a 15 inch rimm???
Old 10-31-2007 | 12:20 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i know 275's r pushin the 15 inch rim limit, but i really want a wide tire. Its a daily driver, but ido take it to the races when i get my chances. I am not worried bout tire wear, for i am a college student with no bills. lol Please and thankyou
Old 10-31-2007 | 09:12 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Re: 255 or 275's on a 15 inch rimm???
If you want a really wide tire and have no bills, get wheels of the proper width. It's hard to directly advise when so much information is missing (your current wheel width, desired tire profile), so I'll refer you to the tirerack.com site. Look on the 'Specs' pages for models of the tires of the size(s) that you're interested in. Best acceleration traction for any given tire probably comes with wheels at or within 1/2" of the "Meas. Rim Width". Better cornering/handling comes with wider wheels, better ride with narrower. Mounting tires on wheels narrower than the narrow end of the given range is not a good idea for anything but very temporary use when there is no alternative.
Norm
Old 10-31-2007 | 09:35 AM
cajunnola's Avatar
Car: 1992 Camaro RS
Engine: 305 (for now)
Transmission: 5-speed
Axle/Gears: stock
depending on the height of the tire and wheel width you should have no problem putting 275's on the rear. just do a little home work.
Old 10-31-2007 | 02:57 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Well i have 8 inch wide rims. 15 in high and ya.
Old 10-31-2007 | 04:49 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
go with 295s then.
Old 10-31-2007 | 05:15 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I know this may be a dumb question, but I have narrowed my tires down to 3 different ones. The uniroyal gt The bf T/A's or the indy 500 ---- im leanin toward the 500's
Old 10-31-2007 | 05:57 PM
studdmstr's Avatar
Car: 91 Z28
Engine: LB9
Transmission: auto
Go with the 275's. You won't see much of a difference between the width of a 275 and a 295 mounted on an 8 inch rim. If you mounted the 295 on a 9 inch rim and compared it to a 275 on an 8 inch rim then there would be noticeable difference.
Old 10-31-2007 | 06:07 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
run 275's.. my sig pic is 275/50-15 mt drag radials on 15x8's
Old 11-29-2007 | 02:18 AM
Kurt04's Avatar
Whats your BS? Stock width rear? Any work to make them fit?
Old 11-29-2007 | 02:41 AM
emory 4-4-2's Avatar
are you talking about just on the rear or all the way around?
Old 11-29-2007 | 02:45 AM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
I just installed some 255/60/15, they are GREAT.
https://www.thirdgen.org/forums/cama...new-tires.html
Old 11-29-2007 | 05:42 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have 295s on the back of mine, couldnt be happier.
Old 11-29-2007 | 05:44 AM
5678TA's Avatar
Car: 1984 Trans Am
4.5" bs, stock rear width, just a slight bit of clearance with a hammer.. should fit without a hammer.. my rear wasnt center..
Old 11-30-2007 | 10:39 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
i just ordered a set of mickey et street radials 275/50/15 they are going on my prostars 15x8 with a 4.5 inch bs how much clearence needs to be done. ive had 275/60/15s on for the past two weeks until i got my new tires. i have heard them rub probly 3 time on big bumps.
Old 12-01-2007 | 04:31 AM
5678TA's Avatar
Car: 1984 Trans Am
you want about 1/4-1/2" of clearance.. you have to mount them and see what needs to be done.. i just go by, if i can fit my finger in the space, its good.. never did rub..
Old 12-02-2007 | 01:31 AM
83 Crossfire TA's Avatar
I ran some 275/50’s on some 0 offset rims, basically what you have there with no issues at all, I ran some 275/60’s with a ½” offset (in) and didn’t have any issues except the inside front corner of the tread that was touching just enough to show a clean spot after about a week of driving that I quickly cleaned up with a couple of hits with a hammer.
Old 12-02-2007 | 01:23 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
yea my mickeys will be here tuesday. so thats when they will go on. i no with my 275 60s they have rubbed before. but the 50s are 2 inchs shorter but about .5 inch wider.
BrianChevy
Wheels and Tires
10-13-2015 01:33 PM
LT1Formula
10-08-2015 09:34 PM
PAFORM350
Wheels and Tires
10-02-2015 08:21 PM
Navy8125
Exterior Parts Wanted
10-01-2015 12:24 PM
gord327
09-29-2015 11:18 PM
