4th gen front spindles?
Does anyone know, or has anyone tried to put 4th gen front spindles on a 3rd gen car? I've been looking at some Wilwoods but according to their site, they don't make a full package for our rides. (Something about that doesn't seem right, but hey) I've already got the rear out of a '98 4 wheel disk in the car and will be looking to upgrade those VERY soon after, if not at the same time, as I do the fronts.
Thanks in advance
Thanks in advance
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Re: 4th gen front spindles?
4th gens use a double A-arm setup
3rd gens use a single lower connected to the strut
No they dont work without major suspension changes
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
A board member makes a 4 piston/ 13" rotor WilWood kit for our cars that fits in the 16 inch wheels. What I'm going with as soon as I can afford it.
Thanks again guys. Might have to look into that kit you mentioned. Eventually, I want her rolling on 18" Centerlines though....
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
these are expensive but they are for 3rd gen camaro
http://www.racecraft.com/products.php?cat=46
search him up hes on thirdgen.org
Car: 1991 RS Camaro
I was just mentioning th 16s because you can run with the stock wheels. Which is good for me because I run the stockers in winter with all seasons.
His screen name is ebmiller88. Good guy, I bought my 4th gen rear from him.
I retrofitted a Wilwood's 4th gen 6 piston brake kit onto my 3rd gen with custom hubs and brackets. It wasn't cheap but it is 13inch rotors and 6 piston calipers on aluminum hubs under factory 16" IROC wheels. Been on there 3 years daily driven and working great.
Here are the specs to follow on this page:
http://www.cardomain.com/ride/518752/6
My next brake build will be C6 Z06 6 piston calipers and 14inch rotors on the front of my '89 C1500 truck. Rears wil be 4 piston 13.4 inch Vette Z06 rear setup also I should have this done by about Feburary08- I am making a Z06 themed truck right now.
http://www.cardomain.com/member_page...2_151_full.jpg
Car: 1991 RS Camaro
And that's a *avoids cliche* idea on the truck.
1992rs/ss
05-19-2020 07:02 PM
ambainb
04-25-2016 09:21 PM
1992rs/ss
16
01-28-2016 09:58 PM
