rear end configuration...
I was hoping to make better traction in the back with my rear and tires... What are the largest rims and tires i can fit on my stock rear and what should i do to the rear end to handle a 383 stroker with 450ish hp?
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: rear end configuration...
depending on what gears you have, i would say either a 275/50-15 (26") or a 275/60-15 (28").. both can be put on a 15x8" rim with 4.5" backspacing or a 15x10 with 5.5" backspacing..
right now i'm runnin the 15x8 setup with a 28x11.50 hooiser qtp tire.. its about the same size as a 275/60-15..
EDIT: the pic in my sig is the 15x8 and 275/50-15.. that was pretty good for the street..
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
