Chassis straightening prior to SFC install?
Is it neccessary to have my frame straightened out before I install Subframe Connectors? I've heard of people doing this if their car's been hit before, but mine has never been in a accident. However, it does have T-tops and an L98, which has probably led to some flex over time. It also has 67,000 miles on the clock, if that makes a difference.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Chassis straightening prior to SFC install?
couldn't hurt to have it checked . might cost a few $ , but it would give you peace of mind . might not cost anything if the same shop is going to install them for you .
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I need to have mine checked. My car has 169,000 miles on it and I've driven the crap out of it over the last 4 years I've had it. Thanks for the idea.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
mine cost me 70-90 dollars a few years back. took about 2 hours, IIRC.
just make sure to have the suspension loaded during the install.
also, make sure they use enough welds! I need to take mine somewhere to add some more. don't let them take it off the lift until you're happy!
4 yrs later, and I need to take my car back in to have a few more welds added.
BlackphantomZ28
08-22-2015 01:00 PM
