Strange noise - Spoon Torque Arm?
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Here’s a question for those of you who are running the Spoon torque arm and cross member. I just swapped in a T56 along with one of these cross member & torque arm combos. Anyway I noticed that I can hear this clunk sound when driving. It seems to do it when I first take off from a stop, slow or fast it doesn’t seem to matter. It also occurs when costing and I hit the brakes or when crusing and I let off the gas. Is this just the shackle on the torque arm moving or do I have a problem. I purchased it with the polyurethane bushing instead of the spherical rod ends because it was supposed to be a bit quieter. I’m just wondering if it is normal for this torque arm to make any noise.
Re: Strange noise - Spoon Torque Arm?
its probly just the shackle/swinging mount that Spohn uses... it does move around quite a bit. i'm running their torque arm and crossmember for my 700r4 and it makes alot of noise just as you describe...from starts and braking. its just the mount shifting around but double check everything to be sure
Yea that's what I figured but it made me wonder after doing a tranny swap that I had to rebuild myself before I put it in. I really doesn't sound like it is tranny related. I'll be sure to take a another close look next time I have it up on the jacks. I did notice that the shackle was very close to the tail housing on the transmission. Has anyone had any problems with the shackle hitting the tranny?
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
good luck
thanks
anthony
it can still move but mine had been taken apart and was not tight enough. its snug enough to not make noise but loose enough to still move.
thanks
anthony
thanks
anthony
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Either that or take a look on the drivers side of the trans tunnel. There is a bolt there that hits the torque arm. It only happens on a few cars. It is a bolt that holds the fuel and brake lines to the car.
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
I'm confused - are you guys talking about tightening the bolt that goes through the poly mount? or are you talking about tightening the bolt that goes through the mounting piece that holds the poly mount?
the bottom bolt where it mount to the crossmember.
I believe the bolt where the poly is can be tight since there is a bushing.
the bottom one is metal to metal contact I believe and needs to be able to swing some.
Engine: TPI350
I wish Steve would chime in on this... maybe if we had only spelled his name right in the subject haha
lol at the comment of spelling his name wrong, spoon builds high revving honda powerplants, spohn builds kick *** suspension components which reside under my car
thanks
anthony
Haha. Yea I know its spelled Spohn, apparently it was just a typo.
That bolt at the bottom of the shackle is supposed to be loose but I may have it too loose. Also I never noticed any interference from the fuel line bolts so that might be it. I'll have to take a look this weekend.
Here's another question. My stock cross member had two bolts on each side. The Spohn cross member has three holes on each side but this third hole on my car is not tapped. Should I tap it and put in that third bolt, it that needed? If so, what tap size would match the stock bolt?
Engine: TPI350
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
So after reading this thread, I finally took the time this weekend to get up under my car. The bottom bolt (without the bushing) was indeed loose, so I tightened the living hell out of it. On the way home I backed up, no clunk, took off quickly, no clunk. Yay! Then going through the curves I downshifted and CLUNK.
I'm assuming its loose again since its clunking everytime I backup and takeoff.
This is a shitty design if you ask me.
So does anyone else have a problem with their torque arm making noise? If so, were you able to correct it? I've tried both tightening and loosing the bolts on the shackle. When I do this is basically makes different sounds but never goes away. When I grease it, it seems to quite down but that only lasts for a couple of days.
I hate this freekin thing. It makes my car sound crappy like it falling apart. I also have wheel hop now which I never had before. I'm thinking about swapping back to the factory torque arm but haven't decided yet.
MD Formula - Did you have any problems with your arm making noise? I see that the shackle on yours is leaning back at almost a 45* angle. I wonder if that is good or bad or makes any difference? The shackle on mine is straight up and down.
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I took mine off because of it, as well as the driveshaft loop making contact with the TA. I bought mine in 03, and since then I guess they oval the DS Loop. Mine did not even come with the rubber insulators that you see on the photos. My car is a street car in the 15s maybe, so i think that it is a bit overkill. As were all the poly/spherical LCA.
I went back to stock TA and LCAs for now. Still have a spherical link panhard.
Car: 1984 z28
Engine: BBC
Transmission: TH400
I used to have a clunking problem with my turbo spohn crossmember. I fixed the problem with subframe connectors. My driveshaft loop was hitting my transmission tunnel when I was driving down the highway, this only happened because of the flex in the body. Subframe connectors stiffened everything up and I've never had the problem again.
My drive shaft loop is not hitting the floor. It's not that close. I actually just got sub frame connectors put in my car tonight, but not because of this problem. The noise is still there. The car feels much better with the frame connectors though.
graebz28,
How do you like the stock torque arm compared to the Spohn piece? I assume this got rid of the noise. Did you change the cross member as well? What bracket do you have to use to hook the stock torque arm to the T56? Can I use the bracket that was on my 700R4 or do I have to use a bracket from a T5 or T56? Is the torque arm from my automatic the correct length?
graebz28,
Car: 89 TTA
I just installed my spohn torque arm and guess what!, bang! evrytime it shifts from 2nd to 3rd.WTF? 1st to 2nd feels great.
I dont get it,why is 1st to 2nd is good smooth firm and quite but 2nd to 3rd I hear and feel a clunk kinda like a busted trans mount,but my mount is new.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
It is the design of the arm, it is going to make noise like that, IMHO it is a poor execution of a descent design. It is a pretty easy fix, if you put a little though into it, and think about what the purpose of the design is. It works, it just needs the execution of the design fixed. With not much fab skill, and a few bucks, you can fix it yourself. if you want to PM me, I'll go into more detail, but I am not going to go about fixing peoples products for them for free on the internet.
Ragtop Man
09-12-2015 12:23 AM
