Torque Trust II fitment for IROC
Old 04-25-2007 | 10:03 PM
pasch's Avatar
Car: 87 Black IROC and a 73 Z28
Engine: 305 in the 87 & a 406 in the 73
Transmission: 700R4 in the 87 a M21 in the 73
Axle/Gears: 4:10 and 4:10
I know that there is tons of threads already. And after reading for a day Im still not shure about what is the widest rim and tire I can fit without rubbing.
Im trying to stay around the 17in size. The car had been lowered about a inch with some Ibach springs. I could care less if the fronts rub in and out of the drive way. I have just had too many differant recomendations to make a choice. I drive hard on the road and am looking to pull hard corners. Also does any one have a great tire combo for the same that looks agressive as well as it works.. I would love to get a 17/9" or larger. Also I don't care if the fronts are of differant size. Is ther anyone out there have this exact sizes to go by ? Im also interested if a differant rear end would make this job better. Im not shure but is a 4th gen camaro diff the same or more narrow and is this a option. Then again I not shure that's why Im asking all you pro's
thanx in advance
Paschthrash
Old 04-26-2007 | 10:15 AM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
Re: Torque Trust II fitment for IROC
I am running 17 x8 with 4.5 back spacing on the front. And 17 x9.5 with 5.5 back spacing on the rear with no problems.
Old 04-26-2007 | 05:02 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I'm running 17x8 all around with 4" backspace and -11mm offset (one of the two mass produced wheels listed for Firebirds with 16" wheels, the other is 4.75" BS with +8mm offset) and mine is lowered with Eibach Sportlines. I get a small bit of rub at full lock turns and that's it. I was going to get 9.5" is the rear but couldn't wait to have them made at the time so I may get them later.
The 4th gen rear is wider by approximately 2". TT2s are mass produced in 17x9.5" for 4th gens as are the 17x11s. You'd wind up running spacers up front if you went the 4th gen route unless you like having more rim showing up front than in the rear.
Old 04-28-2007 | 10:04 AM
pasch's Avatar
Rite-On
Thank you two for replying so quickly. Im going to go 4 it 17/8 and the 17/9.5. I do a couple mesurements today
Thanks again
Pasch
Old 04-30-2007 | 10:45 PM
Whips89RS's Avatar
Car: 72 Malibu, 89 RS & 04 Z71 extended
Engine: (2)350's & 327
Transmission: auto/T5
Axle/Gears: 4:11, 2:73 & 3:73
I am running 17x8 front and 17 x9.5 in the rear stock height. I am installing eibachs and konis in the next week or so. No problems. Pics in vb garage.
Old 05-01-2007 | 06:35 AM
pasch's Avatar
Onec again "thanks for replying" On your Wheels do you know what ofset you have and what tire are you running. Do you like the tire ? Last thing,did you need the rims custom made ?
Thanx in advance
Paschthrash
AussiePr0nCar
03-06-2020 05:04 PM
litemupp
Southern California Area
08-23-2015 11:09 PM
kah992
08-19-2015 03:55 PM
mustangman65_79
08-11-2015 04:17 PM
