Rear sway bar brackets
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Any one know where to get replacement rear sway bar brackets? I need the U bolt and the mount perch for the sway bar bushing. Stock bar. I cant find them anywhere.
Re: Rear sway bar brackets
I have had to fabricate some in the past. when you need a wider flat spot for the bushing to rest on, take some flat bar stock the same width that you need and weld it to the muffler clamp after drilling the holes in it for the u-bolt. It will work perfect. May not look perfect but will work just fine.
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
try a junk yard. most people take the bars not the brackets.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
