MT drag radial sidewall
Car: Camaro
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3.27 9 bolt
Can the vehicle still corner with drag radials or do they have a different sidewall? Thanks
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: MT drag radial sidewall
i have a set and i wouldnt try any hard cornering.. they are awesome for raising hell at a stop light but cornering should be kept to normal-slightly aggressive.. the sidewalls are not quite as stiff as normal street tires.. keep in mind, they are primarily supposed to be used for drag racing.. just get a set of BFG KD's or KDW's and be safe..
