9-bolt fluid capacity?
Old 03-02-2007, 10:30 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Does anyone happen to know off-hand what the fluid capacity is for a 9-bolt rearend? I've tried looking on the FAQ page, as well as in the tech articles, but the closest thing I've found is this article, which doesn't state how much fluid is needed...
(I'm trying to get everything I need to install the 9-bolt cover from the recent GP...)
Thanks guys.
Old 03-03-2007, 12:19 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You need to be in the Tranny/Drivetrain forum. Its 2 quarts, as per this thread:
https://www.thirdgen.org/forums/tran...-capacity.html
Old 03-03-2007, 10:49 AM
V8Rumble's Avatar
Thank you sir. (Apparently, I spend too much time reading this forum... )
HoosierinWA
10-07-2015 10:15 AM
meeklay812
10-01-2015 03:46 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
mfp189
09-27-2015 09:25 AM
6speedIROC
09-13-2015 01:29 PM
Quick Reply: 9-bolt fluid capacity?
