Rear suspension fabrication
Car: 1983 z28
Engine: 383 .060=388
Transmission: th350
I was just wondering if any one here has fabed up any part of there rear suspension? i.e rear control arms, panhard bar, torque arm, if so I would to know where you got your designs.
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
More than likely they looked at the designs of others(companies) and changed them a bit to suit any other needs they have such as exhaust routing or... well, that's about the only reason you would need to change anything on the suspension. Possibly to make it stronger. I.E. thicker/different materials.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
check the fabrication board, many have done that sort of thing.
bjpotter
01-22-2019 12:27 PM
