Other names for Centerlink?
Car: 1991 Formula
Engine: 5.0 TPI
I've heard it called a "drag link" before so I was wondering if it had other names.
I'm in the market for a new one (my alignment guy says the GM part will give the most miles - true or not, I was looking anyway) and I can't seem to find one on gmpartsdirect.com.
Thanks,
Scott
Thanks,
Scott
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Go with MOOG its much better than even the OEM parts.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Center link is a center link but it acts something like a drag link.
The center link fits between the pitman arm and an idler arm. There's a left and right tie rod with left and right tie rod ends attached from the center link to the steering arms on both sides. Equal force is applied to each wheel directly by the pitman arm
A drag link attaches from the pitman arm directly to the steering arm. There's then a single tie rod connected to the steering arms on each wheel. Turning the steering wheel applies force to the left wheel through the drag link which then forces the right wheel to turn through the tie rod.
Car: 1987 Firebird Formula
Engine: 305 LG4
Another vote for MOOG instead off oem for the center link. They are good pieces or you can go with the top of the line NAPA suspension stuff which is also very good.
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
Scottlb9 -
Any luck finding a new centerlink? Just had my shop mount & balance new tires, and they said that they can't align the car because of a bad centerlink.
Please let me know how you made out.
KZad
KZad
Received 1,838 Likes
Everyone says to go Moog. What's the benefit of spending the extra coin on a centerlink? Seems to me like pretty much any brand should work relatively the same... no?
Car: 88 Firebird - SOLD!
Engine: 2.8L
GM Draglink
Check the link below. They have a Delco draglink for ~$83
http://www.rockauto.com/
ACDELCO Part # 45B0075 {#88910971}
ROD,STRG LNKG RLY -; LEFT HAND$82.79$0.00$82.79
Corky
Corky
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Re: GM Draglink
Gong to bring this back from the dead here... rockauto has both a centerlink and a draglink listed. It sounds like they are the same, so I can buy the Moog centerlink (#DS1049) instead of the AC Delco draglink (#88910971), correct?
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Re: GM Draglink
Autozones Brand "Duralast" is accually MOOG. I've used name brand MOOG on my Formula dna ll Duralast on the camaro and both are perfect , look identical and identical part numbers. Some of the parts were even stamped moog.
Engine: 2.8 MFI
Re: GM Draglink
they may be made by moog, but ill wager that they are not the same as the top of the line parts. The parts store ones like that are probably the parts that moog makes that are defective in some small way but still functional.
They have to cut almost $40 off the cost of the moog part some were and its probably not from there profit.
Thirdgen89GTA
11-26-2015 11:04 PM
3.8TransAM
09-27-2015 08:37 PM
roysatikas
09-22-2015 08:15 PM
19821992, anothernameforadraglink, body, brand, center, centerlink, centrelink, delco, drag, fits, forces, link, moog, names, steering, suspension
