drag struts and shocks
Car: 1984 trans-am
Engine: 355
Transmission: ati 350 turbo
Axle/Gears: moser 12 bolt with 411
what drag struts and shocks work the best?
Competition Engineering has a 3 way adjustable rear shock. I use these on my car. They have 30/70, 40/60, and 50/50 settings They also make a strut too, but I'm still using the stock struts on my car. The strut is a 90/10. The prices are fair, but, Lakewood makes a less expensive strut for our cars as well. Getting into the Konis will cost you some money. I would imagine they all work well. Never really heard any complaints. BTW, Welcome to TGO. We are practically neighbors.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use Koni SPA1 on the front and rear. When my 4-link goes in, I'll have some Competition Engineering coliovers on the rear.
Car: 74 Nova
Engine: 383
Transmission: TH350
Do you want externally adjustable shocks or do you want to remove the shocks each time when an adjustment is needed?
Car: projects.......
Personally, I hate 90/10 struts. The front of the car takes longer to drop back down, if it every fully does in a pass. This means unusual amounts of airflow under the car. Good back shocks are deffinitely a good thing, I fully agree on adjustables, my new chassis will have QA1 coil-overs.
1.6X 60fts out of mine on 17" wheels with KYB stock-replacement fronts and cheapy Monroe sensa-junks out back.
LT1Formula
10-08-2015 08:34 PM
3rd, adjustable, camaro, competition, drag, engineering, fbodys, gen, generation, koni, shock, shocks, spa1, sturts, stuts, thiird, works
