lakewood traction action lift bars
Car: 89 Formula
Engine: 305 is out and BBc is going in
Transmission: not sure
anyone buy them howed they work for you they worth the money and got any pics i wann c how they look on the car.
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
i got them for dirt cheap new in a package deal of a member. Car has not been driven hard as Ive been building it for about a year and need to change the gearing. Heres one pic i have showing them from behind.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Junk. Just a gimmick suspension part. Will work for a while but not a true performance suspension component.
Car: 89 Formula
welll what should i go with i like how they looked to bad they dont work as good as they look is there any sort of traction bars for these cars?
Car: 87 IROC L98
Unlike a leaf spring car, third gen suspension doesn't need "traction bars". It doesn't get axle wrap like a leaf spring car does.
Buy a good adjustable torque arm, some good LCA and some LCA relocation brackets.
- You don't need "traction bars" with our suspension, that's why there are none made. The suspension is a link-type, not leaf spring, therefore it doesn't have axle wrap issues.
Yes, the lakewood bars are junk, many a mild 305 has broken them. Do a search before you post, you'll find tons of info. - not trying to bash you, just noting the sticky at the top of every board
Car: 1985 z-28
Engine: 350ci
I dont think he's worried about you bashing him, unfortunately im the one with them on my car......
I havent even driven off my street with mine yet, due to building it and not having inspection yet. I can take off the plates and adjustable piston and weld on Reloc brackets. THen they are pretty much an aftermarket LCA with poly bushing. Got em brand new for $50, cant beat that. Well see if they are still on my car after i swap the gears and diff this coming month.
Car: 87 IROC L98
I think the idea of them is good but any traction device that "clamps" onto the diff in any way, isn't going to be the best design. It would also need to be made from heavier material to reduce or eliminate any chance of breaking or bending.
In a way, they're sort of like mini ladder bars but the short length limits any real potential for a performance product.
darwinprice
17
10-11-2015 11:51 PM
