wheel spacers
wheel spacers
will 1.75 spacers work for swaping 4 gen wheels to a 3rd gen car
thanks for the info
thanks for the info
Car: 1991 Camaro Z28
Transmission: Built 700r4
yah but 2inch is better
go here http://www.skulte.com/adapterfaq.html
for suggested spacing for your car
I have the 2inch and they fit perfect with my ss wheels
they fit in just the right spot and wont sit inside to much. They look better in MY opinion how about that. everyone has different taste I guess
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Depending on the backspacing of the wheels you won't even be able to bolt the wheel up with the 1.75" spacers. My brothers car has 17x9.5 ZO6 wheels and they clear the strut and tie rod by about an 1/8". No way 1.75" spacers would work here. They don't stick out of the fenders at all with the 2" spacers.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
With 2" spaces, you should also keep the same centerline, thus not effecting some of the steering dynamics. If you don't keep the same center-line, you will change the scrub radius, and that will effect steering feel on the car.
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
You need 2 inch, and possible 2.5 inch if your going with one of the wider wheels like the ZR1. My ZR1s fit with 2 inch, but the tie-rod end is extrememly close to the wheel
