XXX/XX/16
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
XXX/XX/16
Alright I tired a search and I really couldn't fine anythign that would help me out in getting the right tire
I got an IROC Single Stripped Rim.....16X8
I would like to know what is the biggest tire I could run front and back...They don't have to be the same size (front and back)
Front
XXX/XX/16
Rear
XXX/XX/16
Please help me fill in the X's
Front
XXX/XX/16
Rear
XXX/XX/16
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
the front 245/50/16
the rears 255/50/16 you might be able to run 255/50/16 is the front but i think they rub alittle when you turn not 100% sure on that not to many companies make 255/50 any more so just stick with 245/50 10mm wont make a difference you cant tell by looking at the tire on the car anyway! good luck
Later Daniel
Later Daniel
Car: 1987 Camaro
Engine: 400 sbc
Running a 245/50/16 will be your best bet, even though you can squeeze a slightly larger tire on the rim. It is a common size, and you will be able to buy a better tire for less money than if you went to a 255/50/16.
- Justin
- Justin
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
I installed the 245s on the front and the 255s on the back and everything is fine. If u are looking to purchase tires go to discounttiredirect.com it is the discount tire website, but offer a better selection on tires than discount stores. I purchased Falken tires for my iroc in those sizes and they were $290 total. Shipping was free.
