Slicks and Skinnys, what size do i need?
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
I have a 91 camaro Z28, I want to buy draglites but don't know what backspacing, etc I need. I would like 15x10 in the rear and not sure on the fronts, brakes, etc, are stock. Its the first time I'm buying slicks and skinnys and I want to do it right.
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
I am running 15x3.5 with 26" mt fronts, and 15x8 with 5.5" b.s. with 28x11.50's mt et streets in the rear here is a pic for ya.
Engine: 383
Axle/Gears: Stock
Thanks guys, I just ordered the draglites. I can finally go have some fun.
Car: 1991 Camaro Rs
https://www.thirdgen.org/forums/auto...portcoupe.html
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
Check out some posts by mw66nova, I believe his Rodlits are 15x10 with 5.5in of backspacing.
Car: 88 IROC
man i wish i could get some tires like that. the problem i think im going to have is that my car is so low and i dont know how big of a tire i could run with out rubbing/hitting my fenderwells but i guess i will have to figure that out on my own. i doubt anyone on here has 2" drop and running 15x10's and slicks...
Car: '82 Z28
The 26x11.50 would just kiss the fender lip when it bottomed out on the bump stops. I put in those lower control arm relocation brackets and moved the arm to the bottom hole, never had a problem with it squatting down that far again. Try and match up a sticky tire that has the same dimensions as your street tire.
Here's what I'm talking about...
No relocation brackets
With brackets and the taller tire.
Pac J
05-17-2020 10:44 AM
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
