big clunk after swaybar installed
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
I bought front sway bar from BMR,
its a solid 32mm.
after i got it in,
since the size got bigger(by couple mm i guess?)
it seems to me that the bar is touching the pitman arm.
I believe it wasnt like that before installation,
now when I make a turn while backing off,
it makes a huge clunk noise.
it only happens when my gear is in reverse and im turning to leftside while backing up.
is it a problem when pitman arm is touching the swaybar?
or does my problem sound like its something else?
any inputs are appreciated
its a solid 32mm.
after i got it in,
ambainb
04-25-2016 09:21 PM
