Identify the noise game!
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
When i turn my wheel at little more than 50% in either direction, i hear this noise that sounds like driving on a flat tire and it feels like it too. It seems like the wheel wobbles loose on some type of bearing or joint.
Other than that the car drives fine in a straight line or when making slight turns. But when i am pulling into a parking spot or making a U-Turn, i feel like my wheel is about to fall off.
Tire Pressure is fine, and everything else drives smoothly. My dad says its probably balljoints, but i dont see how balljoints would exhibit these symptoms.
Anyways, thanks for the help guys.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
it would probably be ball joints in the steering linkage. perticularly the idler arm on the passengerside. the joints take a punishment and when they get loose they can make all kinds of ailments, event eh tierod ends, if one or both are shot the wheel can flop around a bit and drag/push on turns. something to checnk out
sjorgens
10-01-2015 07:54 PM
