LCA and panhard bolt removal
Car: '92 RS
Engine: 305 TBI
I started the LCA and panhard swap ritual tonight to find all 6 bolts are fused with the bushing sleeves. The car is not a trailer queen, but the under carriage is not heavily rusted. The nuts come off no problem, but no sane amount of clamp pressure will pop the bolts out and the impact gun just spins them in their holes. I don't really care about the survial of the original LCAs and panhard, I just want them out without trashing the brackets. Replacement hardware is on the way so I expect the bolts to die horribly. Has anyone found a good way to get the bolts out? (Note: I don't have a plasma cutter.)
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Soak with PB Blaster and let sit.
If that doesnt work, only extreme force and heat will work.
U can also cut the poop out of them, but if fused together from rust it will still be a not fun process.
later
Jeremy
later
Jeremy
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I had to use my angle grinder, to cut them into tiny chunks. Went through a couple of cutting discs I think, not a fun job.
Hint, goop the new bolts with anti-seize or the poly bushing lube. heck just about any greasy substance that won't wash off will help. Copper anti-seize is my suggestion though.
1992rs/ss
05-19-2020 07:02 PM
ambainb
04-25-2016 09:21 PM
1992rs/ss
16
01-28-2016 09:58 PM
