What did ws6 consist of?
Car: 88 GTA
Transmission: Manual
I did a search couldn't find out anything. Everyone knows that WS6 was a top of the line suspension package, but what exactly did the package consist of (in third gen's at least, not so interested about 2nd and 4th gen ws6 packages.)
Car: '88 IROC-Z medium orange metallic
you got the 16x8" wheels, bigger swaybars front and rear, stiffer springs and disc brakes fall in there somewhere but I'm not sure about what the options were. Also badging, vented hood and I think the shocks/struts were valved differently.
Guest
Posts: n/a
I posted something I complied years ago, there may be a few things I need to update but its close enough.
82:
12.7:1 quick ratio steering
32mm front swaybar
21mm rear swaybar
Limited slip rear differential
4-wheel disc brakes
15"x7" Turbo cast aluminum wheels
P21565R15 Eagle GT's(subject to availability)
Notes: WS6 required on CFI TA's
83 Don't know
84:
32mm front swaybar
23mm rear swaybar
4-wheel disc brakes
15"x7" Hi-Tech cast aluminum wheels
Notes:Required with HO V8, requires ordering Limited-slip rear differential. Specific springs come as part of package.
85:
Gas-pressurized shocks
36mm front swaybar
24mm rear swaybar
4-wheel disc brakes
16"x8" Hi-Tech cast aluminum wheels
P24550VR16 Eagle GT 'Gatorback'(subject to availability)
Notes:Specific springs come as part of package. Swaybar sizes per part listing, not published information, besides thats what my stock 85 had on it
86:
Special springs and bushings
36mm front swaybar
24mm rear swaybar
4-wheel disc brakes?
Notes:Have seen 4-wheel discs as being included and not being included, which also includes or excludes limited slip rear differential. Swaybar sizes per part listing, not published information, besides thats what my stock 86 has on it
87:
36mm front swaybar
24mm rear swaybar
16"x8" Cast aluminum wheels
Notes:Rear discs not part of WS6, mandated with the 350 TPI option. This then required the purchase of the Limited-slip rear differential as well. Purchase of TPI engine requires purchase of WS6.
88:
36mm front swaybar
24mm rear swaybar
89:
36mm front swaybar
24mm rear swaybar
Notes:Rear discs not part of WS6, standard with the 350 TPI option. This included the Limited-slip rear differential as well. Purchase of TPI engine requires purchase of WS6.
82:
32mm front swaybar
21mm rear swaybar
4-wheel disc brakes
83 Don't know
84:
32mm front swaybar
23mm rear swaybar
4-wheel disc brakes
85:
36mm front swaybar
24mm rear swaybar
4-wheel disc brakes
86:
36mm front swaybar
24mm rear swaybar
87:
36mm front swaybar
24mm rear swaybar
88:
36mm front swaybar
24mm rear swaybar
89:
36mm front swaybar
24mm rear swaybar
Buggy Disaster
09-22-2015 01:15 PM
