Edelbrock Strut Tower Brace
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Transmission: 5 speed Manual
I was thinking of getting the edelbrock strut tower brace (EDL-5227). Does it make a decent difference? Also, Do I need to drill for it? And if so on the firewall and/or the strut towers?
most all of the stb's for thirdgen you have to drill the holes in the strut towers.
i had the 3 point edelbrock stb, test fitted it and sold it, i didnt like all the pieces of it. if i get any i will get the kenny brown 3 pt. stb, its all one piece.
subframe connectors help the msot for stiffening the chassis, but from what i have read stb's help tighten p the engine bay some as well.
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
i just bought the BMR one
very very nice piece, and it fits the firebirds too
i think the edelbrock one has hood closing issues on the firebird
plus BMR's is 3 point and very sturdy
The one he's talking about is a 3 point. I have this one on my car as well and I definitely noticed a tighter feel after the install. I'm currently looking for a good 3 point for a TPI as I am converting soon. I'm not a fan of the big BMR logo in the middle of it. If anyone has a pic of the Edelbrock 3 point TPI brace I'd love to see it.
I've had this 3-point Edelbrock EDL-5227 TBI brace for years. Yes you'll need to drill 6 holes. Two for each of the strut tower mount brackets and two through the lip at the firewall. It takes just minutes to remove and re-install, since you're just un-bolting the larger bolts that mount the brace to the brackets and the two bolts at the firewall lip. You can gain some hood clearance if necessary by bolting the firewall bracket to the underside of the firewall lip rather than on top of the lip. Yes the brace adds some stiffening that can be felt.
Lon
Lon
Car: 1987 Trans Am
The Edelbrock may be fine for a Camaro, but you're going to have massive hood clearance problems on a Firebird. Redraif had one (repalced it with BMR, fits the Bird much better), and even after lots of cutting and grinding on the bar it still hit. It hit with her stock hood, and it hit with the Suncoast hood on the car now. The BMR rubbed a little (notched the hood slightly for clearance), but fits nice and is easy to remove when needed. I hate the BMR logo in it too, we'll probably make some kind of plate to cover it.
Car: '87 Firebird
Engine: '89 Corvette L98, unstock
Axle/Gears: 3.23 posi
Below is a pic of the Edelbrock STB on my old '87 Z28 CP racecar.
The very same brace was installed on my '87 base 'bird before the CP car was built, and is now back on my 'bird since the CP car was sold. It fits fine with no "massive clearance issues". In fact, I even raised the strut mounting points by about 3/16" to clear over the top of the adjustment plate. (so I wouldn't have to remove/loosen the STB when I changed from the autocross settings to street settings)
Car: 89 camaro rs
Engine: 2.8l V6
Transmission: auto
Axle/Gears: 10 bolt 3.42
Will such an Edelbrock or similar strut tower brace still be valuable if you already have the "steering box area strengthening bar" or "wonder bar" ? (Spohn and some others make that one) I just ordered that one, havent installed it yet.
Car: 1987 Trans Am
Car: '87 Firebird
Ah, he was speaking of using the TBI/Carb brace. I figured you were too.
My '87 was never injected. The 5.0 was carb'd from the factory, and I went back with a carb set-up on the L98 because it was easier.
Car: 1987 Trans Am
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
STB
Can someone give me a list of STB's that would work on a carbed 88iroc. ive seen alot on TPI but very few on carbed, also which one is the best choice in your opinion
LT1Formula
10-08-2015 08:34 PM
