Can't seem to get lug nuts off
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Ok kinda embarrasing asking something so simple but, I can't seem to get my lug nuts off. I had a guy do some repair on the underbody and when he put the wheels back on, for some reason he only put 3 lugs on all the wheels and tightened them as hard as he could with an air compressor. I went to take em off to do some brake work and I couldn't get any of them off. I stopped because I started to chew the lug nuts. I can't seem to get em off and was wondering if anyone had any advice for me. As you can see in the attached pic the nuts have been shaved a little from my efforts and I dont want to make them any worse. Thanks guys. P.S sorry for the blurriness of the pics.
http://i33.photobucket.com/albums/d6...i/ad708d5b.jpg
http://i33.photobucket.com/albums/d6...Picture340.jpg
1 Post
Car: 92 Firebird vert
Engine: 388ci
Axle/Gears: 3.23 open
First, make sure you have a good quality socket (6 sided) 1/2 drive. Use a long cheater bar and pull like crazy. If they are already torn up, you can buy removal sockets. I had to use them on my firebird because it had locking lugs on it and no key . Might want to ask your mechanic what he did and why?
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Have you tried lubricating the nut/stud with PB blaster or WD 40? Use a six sided 1/2 inch drive socket and a long breaker bar to loosen the nuts after the studs have soaked a while.
3.8TransAM
09-27-2015 08:37 PM
