edelbrock vs. spohn phb
Car: 95 Acura Integra GS-R
Engine: B18C1
Transmission: 5 spd.
is the edelbrock phb adjustable on the car (like spohn?). im tryin to decide between the edelbrock and the poly/rod one from spohn. any recommendations?
spohn, they use high quality rod ends... thats the reason for me voting them, if someone else has any other reasons for or against go ahead, but I believe spohn is using the QA1 rodends and those are considered top of the line and worth the extra$$$
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
i will vote spohn as well . people have had bad experience with edelbrock stuff breaking
1 Post
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
I don't recommend rod ends for the street. I had the poly / rod end LCAs They made clunk noise from day one. It just got worse as time went on. The car sounded like a bucket of loose bolts. I changed to poly /poly and no problem anymore.Both were Spohn.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
How long ago did you get the rod ends? Spohn changed to better ones, if I'm not mistaken. I have no noise from mine, but it is on the panhard bar, and it wouldn't make as much noise as the LCAs. Not as much movement.
1 Post
Car: blue
if you bought them 2 years ago, there is a good chance you got the older style rod ends. i have a rod end only rear suspension and they make noise, but it is more of a thud than a bucket of bolts. all the rear suspension is new spohn stuff, phb, lca's, t56 torque arm/cross-member.
I had the Edelbrock piece and the major downside to it was the inability to adjust it on the car. Plus when I adjusted it to the proper length the end with the adjustment was 90 degrees off so I always had to run with the rear just a hair of center and you could tell a difference. I got the Spohn version and it's been right ever since. I also have their LCAs, relocator brackets and adjustable torque arm. Looking at their sway bars and front control arms next.
1 Post
Car: blue
I have Spohn LCAs ,panhard rod, torque arm / cross member and tubular
A arms, all with poly mounts, All work well, but the A arms did lower my front end about 2".
Car: 89' RS TPI,04' HEMI Dodge Q-cab
Engine: 383ci
Transmission: TCI 700R4, 3400 stall
Axle/Gears: 12 bolt 3.73
I just intalled my SPOHN poly/poly adj. panhard bar this past weekend.
I replaced a rod/poly bar that made a ton of noise. Not on the street , but definitley clunked when I launched @ the track(might have somethin to do with my SSM lift bars).
Have not got to test ride the car yet, but I am confident it is going to help a LOT!!
I also bought /installed SPOHN's driveshaft loop that bolts to the crossmember/tranny mount. There stuff is top notch, and you receive their product when(if not before) they say they will ship.
TOP notch company...
I vote SPOHN!!!
I vote SPOHN!!!
Pac J
05-17-2020 10:44 AM
darwinprice
17
10-11-2015 11:51 PM
efiguy
09-27-2015 01:30 PM
Night rider327
09-25-2015 04:47 AM
