235/60/R15 on a Z28/RS wheels
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Ok guys I want to run BFG Radial T/A tires on my RS. I have the 1990 15 inch stock RS/Z28 wheels. The tire size is P235/60/R15. I just wanted to know how well these will fit and if it will throw off my speedo any. Thanks guys.
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
235s will be fine. As suggestion, I'd go 255 in the rear. I think they look better and they give nice handling and traction. The speedo will be very slightly off (at 60 mph, ur speedo will read something like 59.8).
This recent thread talks all about this issue.
UPDATE: Changed the HTML link to vbB link.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Received 1,862 Likes
Yup, they fit great. Probably the all-around best tire size for those wheels. They're about as wide as you can go before you start getting the hot-air-baloon effect. You'll find that there's more difference in the speedo by going from one brand of tire to another, or going from bald tires to new tires of the same brand & model, or going from 25 psi to 35 psi, than going from 215/65 to 235/60.
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
nice handling
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
wheels
buy 16x8 iroc wheels w/ 255/50r16 tires and have superior handling and traction and looks then the 15" with 235width
Car: 91 RS, 95 Z28
Originally Posted by Crusin' 1980's
How could oversized tires on a rim that was designed for a 215 width tire give good handling? I didn't think 255 were that good for cornering when being used on a smaller wheel?
Engine: LB9, LB9
Yeah I want some IROC rims, but the rims and tires are to expensive for me right now considering I might want to buy a clutch.
Engine: LB9, LB9
I could have sworn I did look because I search on almost everything before I post.
drptop70ss
10-04-2015 09:44 PM
