how bigga tire
Car: 84 trans am
Engine: 305 H.O. with small cam
Transmission: th350 with manual valvebody
Axle/Gears: 3:73's
how bigga tire
Im putting in a th350 in my car, and right now i have 215/60's on it(I hate that metric crap). Im gonna put bigger tires in the back to help ring the revs down a lil since in losing overdrive, and i have 3:73s in the back and this car is my daily driver.I want to know whats the biggest tires I can fit in the back with out it rubbing. Does anybody have a well sorted fron and rear comboa that looks good?
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i'm running a 205/70/15 up front and a 275/60/15(28"tall) out back, both on the 15x7" z28 wheels.
Engine: 7.0L
here is a picture of my buddies car with the same 275/60/15's i'm running with a 215/65/15 up front:
Car: 84 trans am
Axle/Gears: 3:73's
aight man thanks. What kinda backspacin is on those rims. I dont have stock rims. Im gonna buy some new ones anyways b/c one of them has some serious curb rash.
Engine: 7.0L
they are 15x7's with 4.25" backspacing. but if your going to be getting new wheels, i'd run either a 15x8 with 4.5" backspacing on the rear or a 15x10 wtih 5.5" backspacing on the rear.
Car: 84 trans am
Axle/Gears: 3:73's
The rims im getton are only available in 15x7 and 15x8. I want the rear tires to poke out just a lil over stock, so with the tires you are running, what kinda backspacing would you suggest for the rear?
Engine: 7.0L
15x8 with a 4.5" backspacing will set them RIGHT inside the fender lip. you'll be happy, i promise. get the 15x7's for the front with a 4" backspace if they have it in that with a 205/70/15 tire up front. the perfect size in my opinion.
Car: 84 trans am
Axle/Gears: 3:73's
aight, thanks man.So I use the same tire in the rear that your usin,or not since ill be runin 8 inches wide? Sound like its gonna give it that slight front rake. Thats exactly what i want.
Engine: 7.0L
use the 275/60/15 tire out back and a 205/70/15 tire up front. it will give it a slight rake.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'd use a 235/60-15 in the front or atleast a 225/60-15. I don't really know why you would want a narrow tall sidewall tire. Talk about mushy.
Engine: 7.0L
i'm running it for the roll out and less rolling resistance at the track, and it looks cool, and it fills up the front fender since it's about 26.5" tall. i like it.
oh, i'm also running manual steering, so it helps with that a BUNCH over the 235/60/15 tire i used to run up front.
Car: 82 Z28
Transmission: TH350
Sorry i really didn't mean you. I know why you have them. I was mainly just talking about a street driven car sports car, not drag racing.
Car: 84 trans am
Axle/Gears: 3:73's
yeah, mine is street only. So you,ve had no problems with a 28 inch tire rubbing? What about the235/60's for the ? How tall are they in inches( I aint no good with that metric crap lol).I like the way your friends black camaro looks. Does it have lowering springs or is it all stock?
Car: 82 Z28
Transmission: TH350
235/60-15 is a 26.1" tall tire.
Here this will help you with the conversion http://www.miata.net/garage/tirecalc.html
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
sorry for asking a question in your thread but i am going to buy a set of drag slicks and was wondering if a 29x9x15 will fit. I know that the width will fit, i just was wondering about the diameter or height of the tire. Do yall think it will rub or anything or should i just go 28"? Thanks
Engine: 7.0L
IHI is running a 29.5x9 hoosier slick without many issues. i think you have to do some "massaging" to the inner fender well down on the front.
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
Tire
With your wheel sizes of 7X15 and 8X15 you want 235/60/15 and 245/50/15. Good street tires in these sizes are 235/60/15 Pirelli P600 and 245/50/15 Dunlop Sp Sport 8000.
Car: 84 trans am
Axle/Gears: 3:73's
I just found out I can only get the rims i want in a 4" backspace. Will this make the rear tires rub the inner fender with the 275?60's?Also, has anyone ever used yokohama avid st tirs, cuz for the value, I think thats what ima get, beacuse i can find the kuhmos that i want in the right sizes.
Car: 1987 TransAm
Tires
The 245/50/15 Dunlop Sp Sport 8000 will out handle a 275/60/15 Yokohoma or Kuhmos. In a straight line the 275/60 is probably better, don't know.
Car: 84 trans am
Axle/Gears: 3:73's
well, im on a budget and dont have but around 500 bucks to spend on a wheel and tire package, and i need the rollout of the bigger tires as this is my everyday driver, and with the th350 and 3:73,s i need to squeeze out all that I can, lol.
Car: 1987 TransAm
Wheels and Tires?
You can't get 2 P235/60/15 Pirelli P600 and 2 245/50/15 Dunlop Sp Sport 8000 and 4 wheels for $ 500. You can buy the tires with $500 and find some more money for the wheels.
Engine: 7.0L
well then, i guess he won't be going with a pirelli tire then, huh? he's already said he's not really going for handling and that he's in need of the large rollout of the taller tire...2 205/70/15 used tires can be had for $40, no need for brand new on that tire, they are MORE than plentiful in good shape.(they came standard on nearly every mid-sized sedan with a 15" wheel.) 2 275/60/15 tires can be had for $175 mounted/balanced from pep-boys. so your up to $215. they you have another $285 for wheels, yeah, he'll probably need alittle more cash, but since the wheels he's getting seem to be so limited on size and backspacing, i'm gonna assume he's getting some type of cheapo wheel. so probably not much more cash.
for $300, you can find a good set of four used draglites or prostars on ebay.
Car: 84 trans am
Axle/Gears: 3:73's
The wheels and tires are outta summit. The rims are cragar series 340's, which i think will look good on a ta.for 4 it comes to 208, then the tires are the yokohama avid st's, 264 brand new for the set so tthats 472, then summit will mount em, rtv balancing (thier own specia thing), and new valve stems for all for just 10 and tire. So thats 512, for an all new tire and rim package.Which is about the best deal i have scrounged up yet.
Engine: 7.0L
eh...i'd look on ebay and see what you can find before buying those wheels. they really don't look that good on our cars, and they are HEAVY steel.
Telstars are going for pretty cheap now, i think you can get a set from summit for about $500 if your willing to wait on tires, but who wants to wait
Car: 84 trans am
Axle/Gears: 3:73's
I would just keep my old rims, since there aluminum and they look good, but the have some serious curb rash on a couple of em. They are mangels 5 spokes, the same as the eagle 5 spokes. Someone even told me thats what eagle alloys use to be called, i unno.How much weight would be saved using aluminum rims verses steel?
LiquidBlue
Wheels and Tires
32
12-10-2019 05:06 PM
