Scary loud creaking noise
Hey guys,
I have noticed this very scary loud creaking noise coming from the back of my car when I drive. Doesn't seem to matter if I turn or go straight on a flat road...all of suddent I hear a loud creaking noise, kind of like the sound a really bad hinge on a door makes but obviously alot louder. I'm stumped.
Car: too many ...
Have you jacked the car up to look under it and see whats going on? From the way you describe it I would guess something with the rearend itself or brakes. Are you sure there isn't something in common when it happens? Maybe some kinda driver input, turning the wheel, stepping on the brakes, etc?
Check the suspension by jacking up the rear and inspecting all the suspension components for worn, broken or missing items. It could be something a simple as a broken sway bar end link or missing sway bar bushing. If all is fine, I wouldn't be surprised if the sheet metal is breaking where the top of the rear shocks mount. To check for this, pull out the rear seat, pull up the carpeting behind the seat back and check the rear shock mounting pocket. If it is breaking you'll need to get someone to weld in a new matal plate custom fit to the pocket.
Lon
Lon
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
Is it only when you go over bumps or is it a constant noise while driving?
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Mine did/does the same thing, but only in the front of the car I still havent figured it out yet.It usually does it when I start to slow down.If you do figure it out you should let me know.
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Did you by chance have the shocks/struts replaced recently?
The rubber mounts ontop of the springs likes to makes very loud noises if you didnt grease them
How much life is left in your rearend?
If youve got alot of play in a differential youll hear a loud noise and feel the diff when small hills and whatnot move a constant speed from load to unload coast
Checked the U-joint lately?
Never heard it stop making noise when it was bad, but never hurts to check it
sjorgens
10-01-2015 07:54 PM
