question about swapping steering boxes
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
my alignment shop told me that i had slack in my steering box....they suggested not trying to adjust it for slack...so i was wondering what steering box i could swap into my third gen to tighten my steering...I have a 92 RS....I want a more performance steering like in trans ams...what year would interchange or would an iroc or Z-28 box bolt in and give me what im looking for?Or is there somewhere I could buy one new....thanks
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
From what I understand it could be one of 2 or 3 different steering boxes depending on the level of suspension the car has.
The dealer should be able to tell you which one you have by the rpo codes.
I recently replaced the box in my 86 Z28. There were 2 options available, 1 for all models except Z28 ($199 rebuilt), and one for only the Z28, ($249 rebuilt).
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
the only ones with a different Box i thought was the IROC with its high effort/ratio one. Meaning it has a faster gearing ratio and is more powerfull to compensate.
edit: you were right there was one for the Base models, one for the Z28/TA, and one for the IROCZ. Dont know about the others but the IROC box was 14:1 ratio. I think the normal one was 12:1?
Axle/Gears: 3:08
how hard is it to swap the boxes out in these cars?...will i need another alignment after i do it?thanks guys...
Engine: 2.8 MFI
Ya i may be swaping mine out for a better one to.
The best steering boxs to look for are the ones that have a ZX code stamped on the front round cover(800mdl).Mostly installed on Z28, Iroc, GTA, Trans Am modles.They also have a square cover on top with 4 bolts & the center adjusment bolt.The lesser low performance boxes had a round cover on top(instead of square,no adjustment)like the round front cover,which are held on by a C-clip.
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I replaced mine with one from agrsteering.com tighted up the steering over the 125,000 mile IROC box I had.
The ratio is pretty quick and has a good steering feel. There not cheap though.
Axle/Gears: 3:08
Will a steering box from a 4th gen work...there are several of them in the salvage yard that i go to...but its hard around here to find a third gen iroc,Z, or trans am.....do any of you know what the rpo...or option code i need to look for on a third gen to find a camaro or T/A with performance steering?
Ive had my AGR box several years now. They come with the fastest ratio GM offered in the 3rd gen.......4TH gens have rack & pinion,not a steering box.You would have to do alot of modifing to install a R&P set-up.Dont know the RPO code, but there is a code stamped on the boxs as stated above,ZX.
backtothe80s
09-05-2015 12:39 AM
